b18 throttle body screw adjust
hi all..
just asking, do you know if that tiny screw with the nut has any kind of adjustment??
the one on the approximate bottom right, the one that holds the butterfly when it closes..
thanks in advance!
thanks in advance!
Re: b18 throttle body screw adjust
yeah it is adjustable. if your idle is too low you can screw it in a little more and it'll open the throttle alittle bit more, not too sure though. but check your idle specs!
