temp gauge not working???
Old Nov 17, 2002 | 10:50 PM
3rdGteg's Avatar
Default temp gauge not working???
My stock temperature gauge haven't worked since I had my head ported/polished. It just stays down, but once in awhile when on a long drive or so, it'll move up a tad bit and go back down. What should I check first?
Old Nov 19, 2002 | 07:54 PM
3rdGteg's Avatar
Default Re: temp gauge not working??? (3rdGteg)
anyone?
Old Nov 19, 2002 | 07:58 PM
Fuuma0083's Avatar
possibly the thermostat?
Old Nov 19, 2002 | 08:12 PM
IN VTEC's Avatar
Check the ECT gauge sending unit. It sits right below the distributor and a little towards the middle of the head.
I don't see how it could have come unhooked b/c it doesn't have a disconnectable connector to/from the engine wiring harness. And I seriously doubt that it was left unthreaded into the head....you'd be leaking coolant all over the place.
The only thing I can think of is that there's an opening in the circuit.
The ECU probably won't pick up on a missing ECT gauge sending unit and throw a CEL code b/c it's not an essential engine management parameter.....the ECT sensor (not the ECT gauge sending unit) handles coolant temperature inputs.
Old Nov 21, 2002 | 06:21 PM
3rdGteg's Avatar
Default Re: temp gauge not working??? (IN VTEC)
Thanks guys, I'll check those out.
GeneBEllis
May 7, 2013 07:01 AM
lacrosse_guy
Sep 30, 2009 04:21 PM
ED6JDM
Nov 19, 2006 12:50 PM
erniecars
Jun 14, 2002 11:48 PM
