TDC sensor issues with balance shift dlete
Old Jan 14, 2011 | 08:18 AM
alex_blackman's Avatar
Default TDC sensor issues with balance shift dlete
Alright so the stock motor in my '99 prelude threw a rod so i bought a rebuilt short block and had it put in.
The oil pump was switched over from the old block to the new one with the TDC and CKP sensors on it.
The problem is the block i bought has a Kaizen Speed balance shaft delete and apparently the TDC sensor reads the balance shaft pulley on an obd2. Now the engine will not rev over 3000rpm.
Should i switch to obd1 so the TDC sensor will be on the distributor?
What all would i need to switch over?
is there any other workaround?
Old Jan 15, 2011 | 02:23 PM
GhostAccord's Avatar
Default Re: TDC sensor issues with balance shift dlete
Or you could put your OBD2 balance shaft pulley on the crank so that the TDC sensor can read it.
akinas-crx
Oct 28, 2011 06:00 PM
teg00blk
Mar 24, 2010 09:46 AM
KingElli
Jun 14, 2005 08:07 AM
EKB18BPR3
Mar 13, 2005 07:22 PM
Huee
Mar 1, 2004 12:53 PM
