TDC on the crank.. Is it the white or red marking.
Old Sep 8, 2002 | 08:32 AM
Spoon Si's Avatar
Default TDC on the crank.. Is it the white or red marking.
What is Top Dead Center on the crank if your trying to set back your timing to stock. There's two markings on the crank a red marking and white marking.
Which one do you line the notch to when trying to set the timing, the white or red marking.
Old Sep 8, 2002 | 08:44 AM
shermanyang's Avatar
Default Re: TDC on the crank.. Is it the white or red marking. (Spoon Si)
i think it's the white marking. i never figured out what the red one was for.
Old Sep 8, 2002 | 10:17 AM
speedymon's Avatar
Default Re: TDC on the crank.. Is it the white or red marking. (shermanyang)
red is for BTDC timing adjustments
Old Sep 8, 2002 | 11:17 AM
IN VTEC's Avatar
Default Re: TDC on the crank.. Is it the white or red marking. (speedymon)
red is 16 degrees BTDC, and the two adjacent marks are +/-2 degrees.
RACING INTEGRATION
Nov 22, 2008 09:02 AM
civc_tt
Jul 25, 2006 09:03 PM
b18c-93
Dec 2, 2002 08:02 PM
allmotor.net
Nov 8, 2002 08:45 AM
