Tach problem
Old Apr 23, 2007 | 08:57 PM
bboyfreeze's Avatar
Default Tach problem
i have a 01 ls turbo and i switched to a obd1 ecu and now the tach cuts at 5k then cuts back on when i go below 5k. Is it possible that the ecu is the problem or is the obd2 dizzy not working with the ob1 ecu.
Old Apr 25, 2007 | 04:59 AM
Day_Walker's Avatar
Im not Banned
Default Re: Tach problem (bboyfreeze)
Is it an aftermarket tacho or just the standard factory one?
Old Apr 25, 2007 | 08:57 AM
JimBlake's Avatar
Got wiring drawings for both years (your car vs. donor ECU)?
In the Accords, the tachometer signal comes from the ignitor up until about '98. On my '98 Accord the tachometer signal comes from the ECU.
Maybe Honda makes a similar change across the board at about that same time? If so, your car is expecting the tachometer signal to come from the ECU, but the OBD-1 ECU isn't producing a tach signal.
GagnarTheUnruly
Engine Management and Tuning
Dec 29, 2011 04:51 AM
OFM_DC2
May 20, 2010 05:53 PM
AErrorist
Apr 22, 2006 03:34 PM
obuhmyuh
Nov 18, 2005 02:02 PM
reaction360
Jan 20, 2005 09:40 PM
