Tach. Jumping Around
Old Dec 6, 2008 | 08:46 PM
LilJohn198807's Avatar
Default Tach. Jumping Around
What would cause your RPM Tach to jump all over the place?
Old Dec 6, 2008 | 08:47 PM
JAY DEE EM YO's Avatar
sensor is bad or wire is loose, or cluster is bad
Old Dec 6, 2008 | 08:49 PM
Cause I figuer it would be the igniter, so replace it, but that wasnt it then put a cap/rotor on it..... that didnt fix it, but made it better so I will look into the wires again.....
How would the cluster go bad?
Old Dec 6, 2008 | 09:02 PM
mtber's Avatar
Are you running any kind of obd2 to obd1 harness ?
If so, what year/make/model is the vehicle ?
Old Dec 6, 2008 | 09:05 PM
solder joints and what nots can go bad in clusters ive had it happen twice before somthin stops workin on it and I replaced everything else and it still didnt work, last ditch option replaced the cluster, and all was fine.
Old Dec 6, 2008 | 09:46 PM
1995 DX Hatch LS/Vtec Swap GSR Ecu has a sir cluster in it....
Old Dec 7, 2008 | 10:57 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
check your ignition control modual (sp.. **** forgot how to spell it), ICM, .. my car used to backfire really bad and tach would go crazy out of nowhere..
Old Dec 7, 2008 | 10:58 AM
Old Dec 7, 2008 | 12:06 PM
I have checked the icm I just put a new one in. It didn't make sense. The car pulls great just tach all over the place. So could it be the cluster?
Old Dec 7, 2008 | 04:25 PM
Old Dec 7, 2008 | 04:26 PM
Old Dec 7, 2008 | 04:27 PM
it never hurst to have an extra, get one and try it if thats not it then sell it on ebay.
Old Dec 7, 2008 | 06:35 PM
Yeah wish I didn't give away all my old sir eg parts when I had it LOL I will see what I can do
Old Dec 9, 2008 | 02:45 AM
purplecivicturbo's Avatar
When i finished my build i had a couple of electrical issues, one of the symptoms i saw was the tach jumping. Although i believe that this would cause more problems than the tach, i narrowed my problem down to the earth point on the thermostat housing. I had neglected to torque it up after i put it on finger tight.. Might be worth checking
Old Dec 10, 2008 | 06:03 PM
arc_55's Avatar
Another thought is to check the shoe connectors on the icm in the distributor ensuring you have a good connection to the icm. I have seen this be an issue at times! Also trace your grounds and ensure they are clean and secure.
efjones9
Oct 24, 2009 03:54 AM
gotgohan
Jul 12, 2009 11:35 AM
spikehead221
Feb 28, 2008 11:28 PM
Wazup
Dec 4, 2007 05:09 PM
Mugenkid
Dec 21, 2004 09:07 AM
