Noob Problem
Old Aug 20, 2006 | 06:11 PM
GoldCoin's Avatar
Default Noob Problem
the other day i disconnected one of my spark plug wires just because and i went inside to go eat. when i came back to the car i tryed to start it and it wouldnt start and then i remembered the spark plug wire i unplugged. i plugged it back in and tryed to start my car and it just kept cranking but wouldnt start. i was thinking it would be the distributor that is messing up . and i just need some ideas on what could be the problem.
Old Aug 20, 2006 | 06:13 PM
mrdeadman's Avatar
They let me pick
Default Re: Noob Problem (DC TWOin IT)
do you have fuel?
Old Aug 20, 2006 | 06:50 PM
BOOSTED RIVAL's Avatar
check to see if it have spark, remove one of your spark plug and crank the motor to see if it still have spark. but put the spark plug wire near a ground to see if the spark jump
Old Aug 20, 2006 | 08:38 PM
GoldCoin's Avatar
Default Re: Noob Problem (BOOSTED RIVAL)
yea i have fuel . but if i dont have a spark then for sure its the distributor? or could it be the spark plugs itself?
Old Aug 20, 2006 | 09:02 PM
If you do not have spark then it could just be your coil or your initer.
Old Aug 20, 2006 | 09:05 PM
GoldCoin's Avatar
How hard is that stuff to change and about how much would the parts be.
Old Aug 20, 2006 | 09:08 PM
It is easy to change the coil. Just call a autopart shop like Autozone for the qoute.
Old Aug 20, 2006 | 09:15 PM
SnIpErS-GsR's Avatar
If your dizzy is bad your tack will not bounce at all. I just had my dizzy go bad in mine. Hope this helps a bit. You might wanna check to make sure you have fuel and make sure you dont have any fuses blown. Hope this helps.
Old Aug 21, 2006 | 06:29 PM
GoldCoin's Avatar
Default Re: Noob Problem (SnIpErS-GsR)
yea i checked all that. thanks for the help . it was the distributor after all . i just replaced it and everything is back to normal.
slk08
May 20, 2009 11:09 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
skata89
May 21, 2006 03:32 PM
gLotex70
May 31, 2003 01:30 AM
