95civic d15b7 no start
Hey guys having an issue with my car. It drove great 2 weeks ago put on about 100 or so milea. went to go start It that upcoming Monday and all it did was crank. I heard the fuel pump prime but seemed like I have no spark. Since then have changed cap rotor coil and igniter. It seems like I have spark now cuz it will studder but won't run. I have checked the ground on the thermostat and also checked the timing twice. Everything looks good. What would be my next step.
Thanks in advance for any help
Re: 95civic d15b7 no start
Test for bright white spark at all 4 plugs using a new properly gapped spark plug.
Make sure the plug wires are installed in the proper firing order on the distributor cap.
Post the CEL codes.
Post the CEL codes.
The car is in proper firing order made sure I checked that and there are no check engine lights on
Alright I'll look into that hopefully tomorrow
okay lets just say the spark isnt bright white what would be the step to fixing that
do i need to get plugs and wires for it
What you mean I haven't gone through a diagnostic procedure the othing thing I haven't done is check the color of the spark. I went from having no spark to getting spark so I think I have gone through some sort of procedure
I never narc'd on nobody!
No, what you did is called guessing, and replacing random parts. You haven't done anything diagnostic. Everything you have posted so far has been guesses and assumptions. Get back to us when you actually HAVE checked the spark color.
