starting and idling problem.. need help
Old Dec 16, 2011 | 09:18 AM
n/aeghatch56's Avatar
Default starting and idling problem.. need help
Hey guys, my civic was running perfectly normal 3 days ago and then we got a huge rain fall and i was driving it died and didn't want to start.. (last time it rained it did the same thing to me, but it decide to start back up and work fine..) I'm trying to figure out what could be the problem, the fuel pump primes up and everything so i don't think that could be the issue, the car is starting but very rough to the point where it could be starting on just 1 cylinder or all 4 but varies. it starts rumbles a little bit, or shoots up to 2.5k and dies.. I'm pretty stumped on the issue.. another thing i should mention was a i got gas during the rainy day, but i don't think the gas was bad. Car is a 94 eg hatch with a b18b1 swap. Any help i would really appreciate just trying to get back on the road so i can go to work thx!!
Old Dec 16, 2011 | 09:19 AM
k2086's Avatar
Default Re: starting and idling problem.. need help
tps sensor
Old Dec 16, 2011 | 09:52 AM
WillM's Avatar
Also, Bad plug wires can cause this in the wet. Open hood at night and watch for arcing between damp wires. You can spray water on them if it's dry, but much easier to see the sparks at night. Just don't touch the wet wires while it's running
Old Dec 16, 2011 | 07:27 PM
ill try those as soon as i can, another note the exhaust gas is a dark grayish/ black and it does shoot flames out on occasion I noticed this while my brother tried starting it
Old Dec 18, 2011 | 01:28 AM
tt
Old Dec 19, 2011 | 11:30 PM
finally got the car got three codes come up which is cylinder position sensor, barometric pressure sensor, and ignition signal... any ideas on what needs to be replaced?
Old Dec 19, 2011 | 11:39 PM
Dioxine's Avatar
Sounds like the dizzy went **** up
Old Dec 20, 2011 | 03:58 PM
took apart my dizzy, looked at the rotor, coilpack, etc everything looks fine... reset the battery... car seems to be working normal right know.. the probably seems to happen only when it rains.. weird
Old Dec 20, 2011 | 05:41 PM
fcm's Avatar
fcm
Old Fart
How is the distributors cap gasket?
#9... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal.
Also as mentioned, pop the hood, [at night] when it's running poorly and look for arcing from the plug leads.
Another thing to check is the spark plug "tubes", make sure there is no moisture or dirt/oil/crap down the tubes or on the plugs, [use compressed air to blow them out]. 94
Old Dec 20, 2011 | 07:20 PM
frankenghia's Avatar
is your ecu getting wet by chance???? move the carpet out of the way of the ecu when its raining and see if its wet down there.
Old Dec 21, 2011 | 07:13 AM
ill check if the ecu is getting wet, and how would you check the wires for arcing.. just pull um out whille the cars running? the gaskets alright
Eduardo Coria
Sep 21, 2013 08:14 AM
NoLongerNA
Mar 14, 2010 07:39 AM
97civic07gsxr
Dec 26, 2008 06:08 AM
dogbiscuit
10
Oct 17, 2005 02:38 PM
Subzonic
Jun 23, 2003 08:16 AM
