Started my first EKswap today, some problems please help.
Old Jul 10, 2004 | 06:53 PM
black sohc civic's Avatar
Default Started my first EKswap today, some problems please help.
Spent the whole day putting in my first swap. Everything went ok except for a little wiring issue. If anyone can help me out, please do.
Car: 97 Civic EX
Motor: 2000 LS
Problem: Left over plugs. After putting on the EX wire harness on the motor. Everything pluged in except these two. Anyone know what they do?
I also have these two connectors left and I dont know what to do with them.
By the rear trans, looks as if its connected to nothing.
Any advice would be great. Thanks in advance.
Old Jul 10, 2004 | 09:16 PM
Chain Driven's Avatar
Default Re: Started my first EKswap today, some problems please help. (black sohc civic)
first pic two plugs look like vtech. ls has no vtech
sec. pic set of plugs(single red/blue wire knock sensor)
(three wire goes to crank sensor in pic three)
fourth pic dead plug
good luck
Old Jul 11, 2004 | 12:23 AM
Mr.Saturn's Avatar
Default Re: Started my first EKswap today, some problems please help. (Rated-R-Garage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rated-R-Garage &raquo;</TD></TR><TR><TD CLASS="quote">first pic two plugs look like vtech. ls has no vtech
good luck</TD></TR></TABLE>
For a 1 post user that spells it vtech... its probably a pretty good answer. The EX harness with have 2 vtec plugs and a knock sensor that you can't use (unless you add it into the block). Any plugs other than that will be a guess from me so I'll leave it up to the experts.
Old Jul 11, 2004 | 08:02 AM
KMaxwell's Avatar
the first pic- its tough to tell by the pic but i believe should be pluged in to the front water neck.
pic 2 is a 3 wire sencor so its not a knock, poss. your o2 sensor , or an assesory
pic 3 looks like a crank angle sensor
pic 4 is a dead plug
I hope that helps, but its tough to tell but the pics
Old Jul 11, 2004 | 10:03 AM
Default Re: Started my first EKswap today, some problems please help. (KMaxwell)
1st pic has 2 plug in it one plug has single wire green Black tape sec. plug has two wire one black other is blue both go to <U>v tec </U>
2nd pic has 2 two plug in it one plug has a single red/blue wire goes to knock sensor
the other is a three wire goes to crank sensor in pic three
3rd pic is crank angle sensor
4th pic is dead
water neck fan switch sensor is in under harness ground
craigmel13
Mar 29, 2018 04:32 PM
dicxonjim
Sep 5, 2012 09:18 PM
thinkbrianthink
Jul 27, 2004 08:20 PM
black sohc civic
Jul 12, 2004 12:23 PM
Civiclx
16
Mar 29, 2004 04:23 PM
