ATTN: anyone with a 1996-2000 Honda civic EX
Is there anyone out there that is an OBD2a or OBD2b that would mind taking a picture of the ecu pin connector 6D if you are an 96-98 or the ecu pin connector 3D if you are 99-00? I am having trouble wiring up my knock sensor and i need to know how to wire it up so i can get my car out of limp mode. The wire coming out of the respective pin is blue/red and is insulated in brown insulation, i need to see where exactly the ground wire coming off this insulated knock sensor wire grounds off. Thanks guys!
Re: ATTN: anyone with a 1996-2000 Honda civic EX (Aquafina)
i need the pictures of the actual Knock sensor wire going into the ecu and how it goes into the harness, because there is a ground off of it and i dont know where to put it
go to the apexi site they have a wiring diagram of all the connectors for all ecu types, look for it in the manual for the vafc or the supplimental insert for the install.
Re: ATTN: anyone with a 1996-2000 Honda civic EX (Grimm)
well i know where the pin is physically, but i dont know how it looks like under the dash. I know for mine (96-98) its on the D pin slot, but i dont know how to ground it (building an ex vtec harness using my 97 dx harness)
New User
Re: ATTN: anyone with a 1996-2000 Honda civic EX (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">Is there anyone out there that is an OBD2a or OBD2b that would mind taking a picture of the ecu pin connector 6D if you are an 96-98 or the ecu pin connector 3D if you are 99-00? I am having trouble wiring up my knock sensor and i need to know how to wire it up so i can get my car out of limp mode. The wire coming out of the respective pin is blue/red and is insulated in brown insulation, i need to see where exactly the ground wire coming off this insulated knock sensor wire grounds off. Thanks guys! </TD></TR></TABLE>
The aem ems forum has a better diagram than the apexi website for ecu pinouts. their colors and location are on it.
at the jetties fishin'
I'm a little lit right now and busy shopping for a boost controller on eBay so this might not be exactly what you need but I've got mitchell on demand on my pc. here's a diagram of the wiring to the ecu for a 98 civic:
if this isn't the shot you needed please count the pins on the harness clips and give me the pin total on the plug you need and what not so I can get you the pic of the wiring you need. please be specific as mitchell tends to number things different...thus "6D" means nothing to me...
also, imagestation might not be working but right now my normal pic hosting site is doing maintainence...
Re: ATTN: anyone with a 1996-2000 Honda civic EX (stackz)
thanks! on that last pic i cant really make out the knock sensor, but it says there is a brown black wire, where is it going off to?
ok, this one give a better look at the grounds, though as you can tell I just cant blow it up enough to show you all of the diagram...
lemmi know...
