engine problems after swap
i have a 92 civic hb and i swapped in a b16a2 and the engine wont turno over and doesnt sound like it wants to but i have power in the car and the fuel pump does turn on and i check the grounds and there is power going to them what can it be??
Re: engine problems after swap (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">you need 4 things to start an engine.
1. Fuel
2. Spark
3. Timing
4. Compression
Make sure you have all of these.</TD></TR></TABLE>
Double check timing. You're saying it cranks but won't start correct?
1. Fuel
2. Spark
3. Timing
4. Compression
Re: engine problems after swap (pappabear)
start with starter or battery. Just because the car has power does not mean the battery has enough power to turn the starter.
Re: (pappabear)
Probably the starter... Is it even getting 12V? Stick a voltmeter on the starter wire at the starter. Check if it gets 12V with key in start position. Check all of your fuses again. You'd be surprised...
Re: (-Darren-)
have you tried jumping it off another car? if that doesn't work, put a multimeter on the starter. maybe the car doesn't see the clutch pedal as being down when you start it.
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">have you tried jumping it off another car? if that doesn't work, put a multimeter on the starter. maybe the car doesn't see the clutch pedal as being down when you start it.</TD></TR></TABLE>
to the clutch pedal sensor
