SS fuel line questions
Old Aug 24, 2005 | 07:16 AM
JICEK9's Avatar
Default SS fuel line questions
I am in the process of upgrading to SS fuel lines and have a question for people that have done this.
Heres the plan... -8an line from the stock fuel filter to STR fuel rail. from STR rail I will use -6an line to connect to SARD fuel pressure regulator. from regulator to return -6an.
Heres the question... what is the oulet size of the <U>OEM fuel filter</U>?
car is 00 civic 2dr d16y8
Old Aug 24, 2005 | 07:54 AM
civicross's Avatar
Default Re: SS fuel line questions (JICEK9)
AN 8 is probably overkill if you are still using the stock filter. AN 6 would probably be a better choice. The outlet size is 12mm x 1.25mm on the fitting, and I have a banjo fitting specifically designed for that spot to go to an AN 6 hose.
Old Aug 24, 2005 | 08:29 AM
JICEK9's Avatar
Default Re: SS fuel line questions (civicross)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">AN 8 is probably overkill if you are still using the stock filter. AN 6 would probably be a better choice. </TD></TR></TABLE>
I was kinda thinking that too. I still may do 6an, but the STR fuel rail accepts 8an in so thats why I was going to do that. we'll see...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote"> The outlet size is 12mm x 1.25mm on the fitting, and I have a banjo fitting specifically designed for that spot to go to an AN 6 hose.
where did you get this bango fitting? I need this part ASAP. any part #, web link would be greatly appreciated. thanks.
Old Aug 24, 2005 | 10:28 AM
civicross's Avatar
Call me at 402-323-3144. The part number is 617-1070.
Old Aug 25, 2005 | 10:08 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross &raquo;</TD></TR><TR><TD CLASS="quote">Call me at 402-323-3144. The part number is 617-1070.
thanks man. good guy as long as the part shows up jk
Old Aug 25, 2005 | 10:30 AM
civicross's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks man. good guy as long as the part shows up jk</TD></TR></TABLE>
It will 53 years don't lie.
Old Aug 25, 2005 | 12:37 PM
JICEK9's Avatar
It will 53 years don't lie. </TD></TR></TABLE>
I wouldn't have done buisiness with you if I had any doubts.
sk8shorty012
May 6, 2009 12:10 PM
h22sedan
Nov 8, 2006 06:02 PM
jaycapz
Sep 23, 2004 09:23 AM
zc911
Dec 20, 2003 10:37 AM
Lyrikz
Sep 17, 2003 07:27 AM
