braided SS fuel line, what parts do i need?
Building a car for my brother and since the main fuel feed line was cut when it was painted (Dumbasses) it;s easier to just run braided line.
What earls fittings and parts do i need to go from the stock fuel tank to the stock fuel filter?
You need a fitting to attach the lines to the tank, a good fuel filter, the reducers to attach the fuel line to both sides of the fuel filter, and then another short section of hose to go from the fuel filter to the fuel rail. Then, you have to figure out a way to attach the lines to the rail. If you're using an aftermarket rail, it will usually be threaded for an AN fitting. If you want to use a stock rail, you have to remove it and tap it for an AN fitting.
