Speedo stopped working need help!!
Old Dec 31, 2011 | 03:40 PM
silencedogood's Avatar
Default Speedo stopped working need help!!
So about 4 days ago my speedometer and odometer stopped working. After a while of driving the check engine light pops on. Im thinking its an electrical issue so me and a buddy tried replacing the speed senser and that didnt fix the problem. So we tried a need speedometer and still nothing.
Bottom line. Im stuck and i need help!
Old Dec 31, 2011 | 04:53 PM
bnetkillzone's Avatar
Default Re: Speedo stopped working need help!!
Wat code is it throwing?
If didnt read the faq's already here's how to: https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Old Jan 2, 2012 | 08:33 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help????? 94
Old Jan 2, 2012 | 02:28 PM
92 civic vx hatch.
Old Jan 2, 2012 | 03:31 PM
turbohatch96y7's Avatar
There should be a 12v aource and ground and signal wire going back to your ecu. Check voltage at the blk yellow. If no voltage trace back to the junction connector and back to the ecu from there. Check your ground that also goes back to a junction connector (fat plug). You will need a multi meter. I'm sure you have a broken. Wire somewhere
Old Jan 2, 2012 | 04:56 PM
DDTECH's Avatar
Its the connector not making a good connection..remove the pins and make them tighter.
Old Jan 2, 2012 | 08:07 PM
a1320addict's Avatar
Unless the pins have been screwed with, it is not possible for them to need to be "made tighter", the connector housings have terminal retention.
To the OP, de-pin the 3-way VSS connector, use electronics cleaner/brake cleaner on the pins and reinsert in their proper cavities.
Most likely corroded terminals.
Old Jan 2, 2012 | 08:38 PM
Do that after you found your input voltage signal voltage and ground. Dont mess up the connector.if you dont need to.
Old Jan 3, 2012 | 04:11 AM
DDTECH's Avatar
Over time, i have found this to be a quick fix actually. They do loosen. But ok. A quick test to see if it is a connection problem would yield better results.
OP Get some wire, 10 gauge, and cut some off. Now remove the outter covering around the wire to where its just plain wire, take a few strands and place it inside the connector of the harness. Re-plugin the harness to the sensor and go for a test drive. Report back.
coupejordan27
Dec 13, 2014 05:14 PM
Coricivic
Dec 11, 2011 07:01 AM
crx_253
Dec 14, 2009 07:42 PM
MASTERJDM
May 14, 2006 11:38 AM
