Need some engine clean !
Old Jan 2, 2012 | 12:25 PM
Steeve_Civic's Avatar
Default Need some engine clean !
I would like to know for Drag racing what I need to keep because there are too many hoses and wiring here!!
- Power steering? Do I need to buy another one but without OEM Power steering
- Do I still need water in the idle vaccum?
- I'm going to change the OEM and Fuel lines too
- Heating
Can I remove the black box (OEM Catch oil take)?
Thank you for your advices!
Old Jan 2, 2012 | 12:29 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Need some engine clean !
yes remove all of that.
Old Jan 2, 2012 | 03:33 PM
turbohatch96y7's Avatar
If all your doing is racing than take out anything that doesn't have to do with transfering energy into motion. Have fun
Old Jan 2, 2012 | 10:39 PM
Old Jan 3, 2012 | 08:49 AM
hondamark35's Avatar
if you remove the OE "breather box" you'll want to replace it with some aftermarket catch can set up or something. it needs to breathe.
you can loop your current P/S rack to convert it to manual. the high and low pressure lines (to the reserviour and from the pump) get plugged and the lines from the pinion housing to the rack cylinder get "looped" together with a T fitting in the middle for a refill reserviour and breather (try using an old clutch MC reserviour from the scrapper.) some racks will need the valving removed when plugging the high/low lines.
the only coolant lines you need are the upper and lower radiator hoses. you can loop the heater hoses, keep the "U-shaped" hose and loop the small bypass hoses to easily close off the system.
luisfer66
Honda CR-V & Element
Feb 19, 2014 08:36 PM
redvelvetsi
Feb 3, 2013 06:01 AM
accord478
Apr 10, 2007 10:44 AM
Topdawgg
Jan 13, 2007 05:38 PM
Dwight Schrute
Apr 26, 2006 07:53 AM
