speedometer not working + code 17
Old 12-10-2011, 02:40 PM
Coricivic's Avatar
Default speedometer not working + code 17
so i just bought the car. it's a 5g civic. it has the stated problem. every oother thread i read is saying it works and then it doesn't but mines is just dead. it's got this cluster except mine is the auto one: http://www.ebay.com/itm/EG9-jdm-Sir-...#ht_695wt_1270
tested the plug. the power and ground both work at the plug. i don't have a voltometer to check the signal wire voltage. also i ran a wire from the signal wire to b10 which is the vss wire. still had the check engine light come on.
one weird thing is when it's driving down the road the cel comes on in the same exact spot every time.
anybody have any pointers? i was going to buy this: http://www.ebay.com/itm/VEHICLE-SPEE...ht_7079wt_1270. it's only 4 bucks.
Coricivic is offline
Old 12-10-2011, 02:49 PM
Default Re: speedometer not working + code 17
Get a multimeter and test for voltage pulses between ECU A26 and B10 as you spin the front wheel.
Former User is offline
Old 12-10-2011, 05:38 PM
Technical Hero
HondaPartsHero's Avatar
HondaPartsHero is offline
Old 12-11-2011, 06:34 AM
Coricivic's Avatar
What's the bEst Way to make contact w/ the wires at the ecu?
Old 12-11-2011, 07:01 AM
Back probe the ECU connectors.
2000CivicEK
11
06-18-2009 05:50 PM
saunders400
04-21-2008 11:07 PM
janz3n
04-28-2006 10:49 AM
EF-21
03-15-2004 04:51 PM
dingusjt
11-13-2003 08:41 AM
Quick Reply: speedometer not working + code 17
  • Ask a Question
Question Title:
Description:
