Some D16 specs......
Old Jan 14, 2003 | 06:54 PM
D-Man's Avatar
Default Some D16 specs......
General Specs for 97 cu in (1.6L) D Series
Bore................2.95"(75mm)
Stroke.............3.54"(90mm)
Deck Height.....8.347"
Rod Length......5.394"
______Compression______HP___________TQ
D16A6.......9 to 1...........108@6000.......100@5000
D16Z6.......9.2 to 1........125@6600.......106@5200
D16Y8.......9.6 to 1........127@6600.......107@5500
Torque Specs
Camshaft Holder 8mm Bolts.....14-15ft lbs
Camshaft Holder 6mm Bolts.....104 inch lbs
Camshaft Pulley Bolt.......27ft lbs
AEM Cam Gear Adjustment Bolts(3 of them)....15ft lbs..apply Loctite "red" to the three retaining bolts
Connecting Rod Nut........23ft lbs
Crankshaft Pulley Bolt.....119ft lbs(D16A6).....134ft lbs(D16Z6)
Cylinder Head Bolts for D16A6
step 1.......22ft lbs
step 2.......48ft lbs
Cylinder Head Bolts for D16Z6
Step 1....22ft lbs
Step 2....53ft lbs
Cylinder Head Bolts for D16Y8
step 1(bolts 1-10)....15ft lbs
step 2(bolts 1-10)....36ft lbs
step 3(bolts 1-10)....49ft lbs
step 4(bolts 1 & 2)....49ft lbs
Cylinder Heads ...All D ARP Studs
Step 1......15ft lbs
Step 2......30ft lbs
Step 3......62ft lbs
Cylinder Head Bolt Thread Size and Pitch.....10mm x 1.25mm
Distributor Mount Bolt....17-18ft lbs
Flywheel Bolt........87ft lbs
Intake Manifold to Cylinder Head Nut..16ft lbs
Main Bearing Cap Bolt........47ft lbs(D16A6)..........Step 1...18ft lbs(D16Z6 and Y8)
Step 2...38ft lbs(D16Z6 and Y8)
Rocker Arm..D16A6
End Rocker Arm Shaft Cap..9ft lbs
All Others and all D16Z and Y8s..........16ft lbs
Throttle Body Nut.......14-16ft lbs
Timing Belt Adjuster Bolt.....33ft lbs
Valve Adjustment Nut....10ft lbs(D16A6)....14-15ft lbs(D16Z6 and Y8)
Cylinder Head Specs
Valve Sizes D16A6 Intake......29mm Exhaust....25mm
D16Z6 and Y8 Intake...30mm Exhaust....26mm
Valve Clearance
Stock D16A6,D16Z6 and D16Y8 Cams
Intake.....007-.009" (.17-.22mm)
Exhaust...009-.011" (.22-.27mm)
Head Chamber Volume
D16A6......................38cc
D16Z6 and D16Y7.....34.6cc
D16Y8......................32.8cc
Throttle Body Sizes
D16A6..... 55mm
D16Z6......56mm
D16Y7......56mm
D16Y8..... 56mm
Flow chart of a D16Y head(stock vs street/strip porting)
A favorite thread i like to visit discussing the Z head vs Y
http://pub143.ezboard.com/fhon...topic
Camshaft Specs
Special Note:You can use a D16Z Cam in a D16Y Head but you have to use the Cam Gear from a D16Z because it'll be a 1/2 timing tooth off..same goes for D16Y cam in D16Z Head,just use Cam Gear for a D16Y..Do NOT buy any aftermarket Cam Gear for a D16Y from a company if they only have one Cam Gear available for the 88 thru 00 Ds.I recommend and use a AEM Gear,they have the right Cam Gears for 88-95s and 96-00s
D16A6 Cams
........................Adv Dur..Dur@.050
........................ Int/Exh...Int/Exh...Lobe Separation...Gross Lift
Stock D16A6.......222/224..194/196........110................333/362
Crane#251-0010.226/228..200/202........107................384/376
Crane#251-0012.232/234..206/208........108................394/386
Crane#251-0014.232/228..206/202........110................394/376
Crane#251-0016.242/244..216/218........110............... 425/416
D16Z6 Cams
Comp Cams and Zex #59100
Adv Duration Duration@.050
___Int/Exh__Int/Exh_Lobe Sep_Gross Lift
PRI..228........186........111..........285
SEC.232........190........115..........300
VT..256.........215........103..........440
EXH.252........210........111..........400
Comp Cams and Zex #59300
PRI..232........190........111..........300
SEC.236........194........115..........310
VT...260........220........107..........455
EXH.268........216........111..........430
D16Y8 Cams
Stock D16Y8 Cam
PRI..211........183........115..........300
SEC.215........187........113..........319
VT...247........217........114..........397
EXH.235........204........110..........370
Crane#252-0010
Adv Duration Duration @ .050
____Int/Exh__Int/Exh__Lobe Sep___Gross Lift
PR.....214.........186.........108.............319
SEC...218.........190.........106.............327
VT.....258.........224.........106.............423
EXH...238.........210.........114.............386
Crane#252-0012
____Int/Exh__Int/Exh____Lobe Sep__Gross Lift
PRI...214.........186..............112...........3 19
SEC..218.........190..............110...........32 7
VT....266.........232..............110...........4 43
EXH..246.........218..............114...........40 6
Some more misc cam specs...
http://www.hadamotorsport.com/....html
Even more cam specs..this time for D16A6s only
https://honda-tech.com/zerothread?id=427814
Here are JG(use at your own risk) Engine Dynamics Cam Specs...
http://www.jgenginedynamics.co...2.htm
D Series Cylinder Head ID Codes
https://honda-tech.com/zerothread?id=786093
Injector science
http://users.erols.com/srweiss/tableifc.htm
http://www.rceng.com/technical.htm
D Tranny Specs
http://www.dmoore.com/crx/tranny.htm
http://home.cinci.rr.com/mistab0ne/tranny.html
A Cool D compression calculator
http://www.knology.net/~jediklc/D.htm
D Turbo Manifolds
https://honda-tech.com/zerothread?id=808342
The Spade HT D Page.
https://honda-tech.com/zero...age=1
Super D Series Piston Comparo
http://www.heeltoeauto.com/dseries/dseries1.html
Massive Mini-Me Write-up by HTs Bauley Civic
https://honda-tech.com/zerothread?id=554053
A D16A6 to D16Z6 Conversion Write-up
http://crx.honda-perf.org/arti....html
D16Y7 to D16Y8 Head Conversions
https://honda-tech.com/zerothread?id=735196
https://honda-tech.com/zerothread?id=622675
https://honda-tech.com/zerothread?id=615978
This guy has the highest WHP Ive ever seen a D produce...
http://home.earthlink.net/~toddm/jamesw.html
he eventually ran 10.4@140 and is rumored to be around 600whp
This is a graph of his D16A6 @25psi
Some other D forums...I dont post in them much cause HT is the best!
http://pub143.ezboard.com/bhondadseries
http://www.d-series.org <---******** actually deleted a post of mine similiar to this one for no reason
http://www.turbod16.com
http://www.sohchonda.com
http://www.d-seriesturboninja.com
How to Adjust D16 Valve Clearance
CAUTION:Always rotate engine in direction of normal rotation(counterclockwise as viewed from front of engine). Reverse rotation may cause timing belt to jump time.Rocker Arms are made of aluminum and can be damaged if lock nuts are overtightened so be careful.
Note: Valves should only be adjusted when engine is cold with temp of it less than 100 degrees F.
Step 1...Remove Valve Cover.Remove Upper Timing Belt Cover.Rotate Crankshaft counterclockwise until No. 1 piston is at TDC of the compression stroke.Up mark on camshaft pulley should be on top,TDC marks should align with cylinder head upper surface or TDC groove should align with pointer on back cover..see pic below
Step 2..Loosen adjusting screw lock nut on cylinder No. 1.Adjust valve clearance to spec on all valves for No. 1 cylinder.Turn Adjustment screw until a feeler guage slides back and forth with a slight drag.Tighten lock nut to spec and recheck valve adjustment..Cylinder No.1 is done
Step 3 Rotate crankshaft counterclockwise 180 degrees(camshaft pulley rotates 90 degrees) Up mark on camshaft pulley should be on the exhaust side.Adjust all valves for Cylinder No.3
Step 4 Rotate crankshaft counterclockwise 180 degrees(camshaft pulley rotates 90 degrees) Up mark on camshaft pulley should be down(both TDC grooves will be visible again).Adjust all valves for Cylinder No.4
Step 5 Rotate crankshaft counterclockwisw 180 degrees(camshaft pulley rotates 90 degrees) Up mark on camshaft pulley should be on the intake side.Adjust all valves for Cylinder No.2
Step 6 ..Ensure crankshaft pulley bolt is tightened to spec
Timing Belt Adjustment
Note: Timing Belt should only be adjusted when engine is cold with temp of it less than 100 degrees F.
Step 1. Remove Valve Cover.Remove upper timing belt cover.Rotate crankshaft counterclockwise until No.1 cylinder is at TDC of compression stroke..see above pic.Loosen timing belt adjuster bolt 180 degrees,see pic below.
Step 2. Rotate crankshaft 3 teeth counterclockwise on camshaft pulley to create tension on timing belt. Tighten adjuster bolt to spec.Ensure crankshaft pulley bolt is tightened to spec.Reinstall valve cover,timing cover and your done!
Bearing Codes
Modified by D-Man at 8:07 PM 8/21/2004
Old Jun 23, 2003 | 05:11 PM
Midwestrider's Avatar
Default Re: Some D16 specs...... (D-Man)
Nice to know on the D16's..
Thx
Old Jun 23, 2003 | 06:08 PM
RyanEJ8's Avatar
Good info
Old Jun 25, 2003 | 01:17 PM
LANL02's Avatar
EXACTLY what I was looking for. I thought it would take me a while to find all this information. Thank you.
Just a lesson out there for you kids.....the search button really does work and can give you mana from heaven.
Old Jun 25, 2003 | 07:18 PM
RyanEJ8's Avatar
You just added a bunch of **** that's going to be real helpful to me tomorrow.
Old Jul 23, 2003 | 01:30 AM
ExospeedAMcrx's Avatar
Default Re: Some D16 specs...... (RyanCivic2000)
Dont Forget Andrew Yang's CRX with turbo D16y8 back in 1997/98.
was doing 10.2 or 10.4 i believe.
Wil
Old Jul 23, 2003 | 03:13 AM
D-Man's Avatar
Default Re: Some D16 specs...... (exospeedAMcrx)
Andrew Yang was that Fast? I couldnt find much on him and the fastest Ive ever found on him was 10.6s..but thanks that is also good new for me since Im using the Y8 head and I was getting worried I made a mistake between what Zex-Man said on that thread up above and the HP/ET West was making w/a D16A6. I'll keep looking for info on Yang...of coarse he doesnt post on HT right?
A Pic I found of Yang in action in 1999
Modified by D-Man at 12:44 AM 7/27/2003
Old Jul 25, 2003 | 09:12 AM
nope, Andrew is out of the scene... doing well in other things.
Old Jul 26, 2003 | 01:01 PM
T4eg's Avatar
thats alot of good info
Old Jul 26, 2003 | 01:21 PM
3RdT's Avatar
Default Re: Some D16 specs...... (BlueHatch00)
goooood ****
Old Jul 26, 2003 | 02:22 PM
notstock93's Avatar
Default Re: Some D16 specs...... (3RdT)
is my math wrong or does that leave a D16 with a 1.52:1 Rod Ratio. Not bad....not good, but not bad.
Old Jul 26, 2003 | 07:04 PM
D-Man's Avatar
Default Re: Some D16 specs...... (notstock93)
your math is right....BTW Sorry all,I dont know what is up with the server that is hosting my pictures..I'm in the process of finding another host for my pics so you all can see something besides red Xs ..should be fix by tomorrow evening..the 27th
Old Jul 26, 2003 | 07:20 PM
smokey2.0's Avatar
good job
Old Jul 26, 2003 | 07:48 PM
JCracer723's Avatar
Default Re: Some D16 specs...... (smokey2.0)
lord thats some good info
Old Jul 26, 2003 | 08:01 PM
976's Avatar
976
New User
Default Re: Some D16 specs...... (JCracer723)
Does someone have a site to host this all!?
Great info bro, thanks for sharing, too bad I have a b-series, err, too bad you don't have a b-series...
Old Aug 8, 2003 | 10:32 AM
D-Man's Avatar
Default Re: Some D16 specs...... (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">Does someone have a site to host this all!?
I use several to host the pics...digitalpose.com,imagestation.com and we-todd-did-racing
Old Aug 8, 2003 | 12:42 PM
piscorpio's Avatar
*stands up and applauds*
Kick *** info, how long did it take to compile all of that?
Old Aug 8, 2003 | 07:59 PM
D-Man's Avatar
Default Re: Some D16 specs...... (piscorpio)
Thanks! Ive been adding little by little over the last 8 months from stuff ive found and have,going to keep adding when I get more time.I think I'm gonna add some more stuff on the lower half like main/rod specs and I want flow charts for D16A and D16Z heads.
Old Aug 8, 2003 | 09:05 PM
The Brown Kid's Avatar
very nice
Old Aug 9, 2003 | 08:44 AM
Default Re: Some D16 specs...... (The Brown Kid)
D-Man,
I'll see on getting your info up on our site and to host it on there. would you like us to do that? just let me know how you want it. The format and placement of the information.
Wil
Old Aug 9, 2003 | 07:05 PM
D-Man's Avatar
That sounds great! but I'm not finished with this yet,gotta lot more homework to do when I find time.As far as format and placement,I gotta lay it out and think about it.Only thing I'll ask of you is too put alittle something under my info like "courtesy of D-Man@Honda-Tech"..........
Old Aug 11, 2003 | 06:38 AM
kay_animation's Avatar
There ya go. Its hosted Thanks for the great information. Now it will go to very good use for everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And now, the new website with a main page design from a picture taken by roaringturtle
http://www.deviantpixels.com (to page intro first)
http://www.deviantpixels.com/main.html (for the intro skippers )
As far as ht stuff on there, I have a good d16 writeup done by D-Man .
Just go to the main page, Click on Honda-Tech Stuff, then click on the D16 specs...... :: By D-Man in the small window, which takes you here http://www.deviantpixels.com/ht1.html if you just want to be lazy </TD></TR></TABLE>
Old Aug 22, 2003 | 06:13 PM
D-Man's Avatar
Default Re: Some D16 specs...... (kay_animation)
Cool! Thanks! now we'll see if you can keep up with my updates
Old Aug 23, 2003 | 12:18 AM
psileepR's Avatar
New User
awesome writeup .. damn what took me so long to find this. to the notepad this goes
Old Aug 25, 2003 | 05:32 PM
4crx4me's Avatar
Default Re: Some D16 specs...... (LANL02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LANL02 &raquo;</TD></TR><TR><TD CLASS="quote">Just a lesson out there for you kids.....the search button really does work and can give you mana from heaven.</TD></TR></TABLE>
Brwahahahahah. ROFLMAO
Good one. Kids, sheeesh.
