smelly situation?
Old Feb 7, 2004 | 06:32 PM
jdmcivicdx's Avatar
Default smelly situation?
when i drive my car around the insie of the car fills up with some insane smell. Im not sure what it is. I figure either exhaust or oil burning smell. Has anyone ever had this problem? The smell is realy strong. Almost unbearable. Any help would be greatly appreciated. Oh and the smell is coming from a civic dx with a b16 turbo.
Old Feb 7, 2004 | 06:38 PM
hondatim's Avatar
Default Re: smelly situation? (jdmcivicdx)
are you sure turbo oil return/feed line or oil pan gasket isn't leaking oil onto exhaust while driving. this could cause issue. Have also seen oil pressure sending unit leak a lot of oil and cause this issue too.
Keep us posted on what you find...
Old Feb 7, 2004 | 07:14 PM
jdmcivicdx's Avatar
Default Re: smelly situation? (hondatim)
thanks. i will check it out tomorrow and let you know.
Old Feb 7, 2004 | 07:48 PM
boostn420's Avatar
If you roll up the windows and leave the fan on and recycle it should pressurize the inside and not let in air from outside. It should make it more bearable.
Old Feb 8, 2004 | 10:08 AM
jdmcivicdx's Avatar
Default Re: smelly situation? (boostn420)
i checked. the oil return line is leaking. gonna have to weld it on now. Ive tried rolling up the windows and running the fan. Works for a lil bit but then the smell returns. could it be since i am not running a catalytic converter?
Old Feb 9, 2004 | 10:14 AM
jdmcivicdx's Avatar
well big puffs of white smoke are now coming out of my exhaust when i shift gears. Im guessing this is bad. What could it be?
Old Feb 9, 2004 | 10:29 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicdx &raquo;</TD></TR><TR><TD CLASS="quote"> could it be since i am not running a catalytic converter?</TD></TR></TABLE>
My friend tells me his car started smelling like *** when he got rid of his cat.
Old Feb 9, 2004 | 08:38 PM
hondatim's Avatar
could have a headgasket leak. how much boost are you running and have you improved bottom end at all?
Old Feb 11, 2004 | 01:48 PM
jdmcivicdx's Avatar
well i was running about 8psi. the bottom end is stock. Trying to save some funds. I think the turbo spiked.
Old Feb 11, 2004 | 04:34 PM
slixxracing's Avatar
I have the very same problem w/ mine also. I have a eg gsr turbo and the smell is really bad and strong. As if someone didnt know how to make popcorn and over burnt it. What I did to get rid of my smell was, FIRST-I took out the turbo kit, SECOND-did an oil change, and THIRD-let my car idle for about 30-45 mins. Now my smell is gone. Im assumming it has something to do w/ the turbo and the oil return line.
Old Feb 11, 2004 | 06:36 PM
jdmcivicdx's Avatar
Default Re: smelly situation? (slixxracing)
damn my turbo kit. i was told that some of the threads in my head where the turbo bolts up were bad. could this be where the smell is coming from? before the kit everything was good. Now it stnks.
Old Feb 11, 2004 | 08:04 PM
dfoxengr's Avatar
smell like rotten eggs, sulfur...
do you burn your clutch a lot, could be that too
Old Feb 11, 2004 | 08:12 PM
Cyphear's Avatar
if the return line is leaking are u sure its not just sucking up oil or getting on something hot and smoking?
Andrew 825SM
Feb 14, 2010 06:05 PM
kenbo21
Jul 30, 2008 05:36 PM
Snafu-Si
Jan 22, 2005 10:21 AM
E Swift
Nov 2, 2002 09:17 AM
GruvyTune
Nov 18, 2001 03:59 PM
