slight hesitation
Old May 13, 2004 | 05:12 AM
turbotegrar's Avatar
Default slight hesitation
when i am driving usually in 1st and 2nd gear what happens is there is a slight hesitation almost in the acceleration, usually happens around 2500-3000 rpm and when i get past three it seems like the car wants to take off....what could it be?
Old May 13, 2004 | 09:58 AM
Ekasey's Avatar
Default Re: slight hesitation (turbotegrar)
can be any # of thigns what mods are done to your car
Old May 14, 2004 | 01:52 PM
porschekremer's Avatar
Default Re: slight hesitation (eLusive ek4)
prob. your timing is retarded, advance it try that out see if that helps you out....
Old May 14, 2004 | 01:55 PM
Default Re: slight hesitation (cruisner)
https://honda-tech.com/zerothread?id=836804
Old May 17, 2004 | 07:16 AM
the only mods done to my car is intake and exhaust for now...well performance mods at least
Old May 17, 2004 | 07:17 AM
my timing has been advanced a little...
Old May 17, 2004 | 08:17 AM
Ekasey's Avatar
check the TPS there may be a burn spot in it try accelarating past that rpm on diffrent pedal postitions
Old May 18, 2004 | 05:10 AM
what is the TPS...?
Old May 18, 2004 | 02:07 PM
jdmotorsports's Avatar
throttle position sensor
Old May 18, 2004 | 06:14 PM
spaceman's Avatar
probably need a tune-up dood
Old May 18, 2004 | 07:15 PM
pyrojeff's Avatar
Sounds exactly like my car about a month ago. Bogged from 2-3k, then just took off after that. Replaced the o2 sensor, and its been running like a champ ever since. The check engine light only came on after i drove for a while, and would not show up if i restarted the car.
Are you getting any check engine lights?
Old May 20, 2004 | 04:13 AM
Default Re: slight hesitation (pyrojeff)
no check engine lights at all...i did pretty much a full tune-up on it about a month or month and a half ago...
mouab18c1
Aug 10, 2012 12:30 PM
f22vx
Jan 21, 2011 07:00 AM
turbotime
29
Dec 10, 2006 10:18 PM
d16y7hatch
Oct 30, 2006 08:57 PM
rice a roni
Jun 2, 2004 11:07 AM
