Skunk2 Intake Manifold & Alpha Exhaust Header Questions
I have a question and I need your guys help and suggestion I'm planning to install a skunk2 manifold header and a exhaust header and I have been doing research and it's giving me for exhaust header either a regular skunk2 header or alpha series skunk2 which one should I use, would you recommend getting gages after installing the parts and is it require to get a dyno tune after I install those 2 parts If so where is the best place I can get a dyno because I live in erie,pa and there is nowhere that has a dyno shop for honda's.
Thank you
Thank you
Re: Skunk2 Intake Manifold & Alpha Exhaust Header Questions
You'll find out really quick that people don't really like to help you here. It is expected for you to do your own research on the internet. But as far as the difference between the headers, the @lpha series is basically a cheaper version of the megapower but better than oem. Gauges are a personal preference, but you definitely need to tune because of the performance upgrade. Dyno...... Unless you thing those two bolt ons will give you tons of ponys, I wouldn't was all that money on a dyno, tune is expensive as it is.
I like the tuna here
What sort of gauges are you talking about, OP? And no, you don't NEED to get it tuned after installing those two things, but to really get performance out of them, yes, it's required. What year, model and engine?
Moderator
Gauge selection really depends upon the purpose of the car. However, I've found that oil pressure and oil temperature are the good ones to have for NA use. It's more than once saved some engines I've owned and experienced.
V-SPEC 1
25
07-19-2016 10:05 AM
VtecKiDD
59
03-28-2006 07:54 PM
kingrat
10-17-2003 07:41 AM
