Shimming oil pump....
Old Dec 22, 2005 | 11:23 AM
gawath's Avatar
Default Shimming oil pump....
I've heard this term tossed around and am not too sure what it particularly means. Can somebody enlighten me on this subject?
Old Dec 22, 2005 | 06:50 PM
rintegration's Avatar
Default Re: Shimming oil pump.... (gawath)
What it means, is that you are placing shims (washers) between the oil pump relief valve spring and the bolt that holds the relief valve assembly in place. In return, this puts more pressure on the spring causing the relief valve to open at a higher psi.
Old Dec 23, 2005 | 08:38 AM
Blackack26's Avatar
Default Re: Shimming oil pump.... (rintegration)
Here is a thread I made a month or so ago, still working very well today.
https://honda-tech.com/zerothread?id=1396607
Old Dec 23, 2005 | 05:40 PM
gawath's Avatar
Thanks for the information guys.
daveedd357
Jul 23, 2005 08:51 AM
PURPLETERROR aka BIGMATT
Jun 21, 2005 03:49 PM
-KangaRod-
Mar 22, 2004 02:52 PM
