Shifting to fith
Old Jan 25, 2007 | 09:10 AM
Tazragoon's Avatar
Default Shifting to fith
alright, this has nothing to do with a honda, but this is the only site i can get to right now.
i am looking to buy this 1990 mitsubishi eclipse with a stock no turbo 92 eclipse engine and a turbo 92 tran.
the guy says it wont go into fith ever since he installed the new clutch and everything, he said it would have to be adjusted and bled.
should i believe him? and when i go to get the car inspected what should i ask the mechs to look for?
thnx for the help.
Old Jan 25, 2007 | 02:46 PM
IN VTEC's Avatar
Default Re: Shifting to fith (Tazragoon)
If the clutch had to be bled, then it wouldn't go into any of hte gears, not just one of them.
Try to row the gearbox into fifth gear with the engine off. If it blocks you out, then you need to look at the shift linkage or separate the transmission from the linkage and isolate the problem to inside the gearbox.
Old Jan 26, 2007 | 07:20 PM
Tazragoon's Avatar
Default Re: Shifting to fith (IN VTEC)
will it still allow the shifter to move? because the shifter goes into all the gears, it just doesnt do anything for the 5th i think
ninja_integra
Aug 17, 2013 10:24 AM
ki11a8ee
Apr 6, 2010 11:54 PM
Pinja
May 6, 2007 09:01 AM
turbo gsr
Oct 2, 2005 06:37 PM
-iLLuZioN-B18C1
Jan 9, 2003 08:02 PM
