transmission problem
Old Sep 28, 2005 | 05:43 AM
turbo gsr
Guest
Posts: n/a
Default transmission problem
i have 94 gsr turbo, the engine has been rebuilt with all the proper internals and an RPS clutch, i am now pushing a little over 370hp however even befor my recient tune i have noticed that it has been very hard to shift into gear, i will often have to stop and let the car set in neutral for a second then it will go into gear i do have a short shifter and am planing to replace it with a stock one. please help
Old Sep 28, 2005 | 09:03 AM
95lstegman's Avatar
Default Re: transmission problem (turbo gsr)
which gear? it's starting to sound to me like you need a new clutch set.
Old Sep 28, 2005 | 12:12 PM
turbo gsr
Guest
Posts: n/a
Default Re: transmission problem (95lstegman)
all gears are abnormally hard to go into and it is a brand new clutch under 5000mi
Old Sep 28, 2005 | 12:19 PM
InteGsRed's Avatar
honda syncro's are ****, Take time in between shifts and that can help, but the syncro's need time thats why alot of guys wont buy short shifter. Try chagning your tranny oil or getting some gm syncromesh,
Does it grind at all?
Old Sep 28, 2005 | 12:59 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (InteGsRed)
Does this apply for all the gears? Does it make it any easier if you rev match to get it in? Does it happen in all rpm ranges?
Old Sep 29, 2005 | 03:02 AM
turbo gsr
Guest
Posts: n/a
Default Re: (shamoo)
yes it happens in all gears and ill try new fluid and deff. taking out he short shifter
Old Sep 29, 2005 | 04:50 AM
95lstegman's Avatar
Default Re: (turbo gsr)
yup even fresh Honda MTF is better than old whatever, but if you must then try GM synchromesh regular. the short shifter isn't the root of the problems, at least it's not likely. if you have a hella clutch (370whp you'd better) and a light flywheel the shortshifter is probably a good idea.
when you're sitting not moving engine on, does it go into gear smoothly?
what about if you're upshifting at 3k rpm?
what about at 7k rpm?
does the shifting at 3k and 7k get better if you revmatch? (assuming you're somewhat skilled at this)
report back with answers and note if one gear operates differently than the rest in these tests.
Old Oct 1, 2005 | 11:53 AM
turbo gsr
Guest
Posts: n/a
Default Re: (95lstegman)
confermed the prob. need new trans. and yes it does it in all gears even when im ideling and even vibrates the car but when i put it in neutral it stops thank guys
Old Oct 2, 2005 | 06:37 PM
95lstegman's Avatar
where do you live?
mugen727
Sep 30, 2009 09:16 AM
the barst
Feb 3, 2003 12:10 PM
Toms96GSR
Jul 29, 2002 01:36 PM
