Setup with tune
Old Mar 16, 2007 | 10:45 PM
mcgee*'s Avatar
Cigarette Squad
Default Setup with tune
The set up as of right now looks like this
Car:
1997 Integra LS
Engine:
-1997 B18B1 LS
-81mm 10.5:1 forged SRP pistons on LS rods
-New stock everything in head
-Nippon rings
-ACL bearings
...so basically stock with new everything
What im looking to do is a t3 50trim turbo, "home-made" turbo kit with 7psi not looking for alot since this is daily driven car and wanna learn before going bigger.
What ive been told...
1.) i do not need injectors as im only running that much psi "stock can hold 12psi"
2.) i do not need to be tune as im only running that much psi (i call bs, but let me know if they r right)
As for as tuning is this correct that i need to have the obd-1 ecu and get chipped for crome, then find a good tuner and go from there roughly amount 400$ for tune or as some people say do a street tune? Which would be good in my case, Dyno tune or street tune? Im not looking for some crazy numbers like 450whp or **** like that just up it to 200 or so.
Thanks.
Old Mar 17, 2007 | 09:42 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: Setup with tune (McGeeTM)
damn still nothing
Old Mar 18, 2007 | 11:44 AM
Whiteintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McGeeTM &raquo;</TD></TR><TR><TD CLASS="quote">The set up as of right now looks like this
Car:
1997 Integra LS
Engine:
-1997 B18B1 LS
-Nippon rings
-ACL bearings
Thanks.
Lol... you are not gonna need injectors if you want to replace your motor soon b/c it blows.
If you want a DD setup, better tune it...or else you will loose it.
unless you plan on spending 1200 for an AEM EMS, you gonna want to convert to obd1 and do the hondata/crome route.
Old Mar 18, 2007 | 06:22 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: Setup with tune (Whiteintegra)
alright so im right?
i DO need injectors?
i DO need a tune?
as for injectors what size should i use something around 200?
Old Mar 18, 2007 | 06:59 PM
Jim Truett's Avatar
i DO need injectors
i DO need a tune
Yes, and look for 440cc injectors at this point.
Old Mar 18, 2007 | 08:35 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: Setup with tune (Jim Truett)
alrighty thanksss!
Old Mar 19, 2007 | 09:00 AM
sauceja's Avatar
http://www.pgmfi.org
Read up on crome and tuning.
440cc or 550cc injectors would be good.
Crome would be safer than an fmu and missing link.
libral00
Nov 25, 2010 07:01 AM
j-robsDA
Mar 31, 2005 07:51 AM
spooledex
Apr 4, 2004 06:53 PM
allmotor92civic
Mar 16, 2004 07:38 AM
dragnGSR
Aug 15, 2002 11:38 AM
