setting my tps
Old Jul 17, 2004 | 05:06 PM
  #26
thinknology's Avatar
Default Re: (Xsi)
i reset my ecu and im no longer getting the ignition code now just the tps and of course its still bogging down when i mash the gas and has stalled three times in a week ...
Old Jul 17, 2004 | 06:56 PM
  #27
Xsi's Avatar
Xsi
Ok, so you replaced the tps but did you set it? the code is almost certainly caused by it not being set properly.
Old Jul 21, 2004 | 03:40 PM
  #28
Default Re: (Xsi)
its set at .45 liek the manual said and i tried taking it lower ".32" but it will only go down to .44 and i found something else out, when i start my car and i push the gas to keeep the rpm above 1k or so the check engine light will not turn on untill it drops down to idle (about 600)... idle screw??
Old Jul 21, 2004 | 08:30 PM
  #29
Xsi's Avatar
Xsi
If your TPS won't go any lower you can try taking it off and bending the pieces of metal that move the tps around, you only have to bend them slightly. This will change the range that the tps goes through.
Old Jul 21, 2004 | 11:09 PM
  #30
spaceman's Avatar
Default Re: (thinknology)
are you still getting a code?..check all your wire connections,check your grounds too..then reset your ecu
Old Jul 28, 2004 | 02:12 PM
  #31
Default Re: (spaceman)
all i am getting is the tps code and like i said it only comes on if the revs drop below 1k or so... still not sure....
TwoKSiR
Mar 25, 2008 11:11 AM
1Bar GSR
Dec 11, 2007 06:44 PM
TheSav
Apr 10, 2006 11:23 PM
ty1585
Mar 28, 2005 01:19 PM
CRX A4
Jun 14, 2003 09:43 AM
