safc hack-missin link question
Old Jun 10, 2005 | 02:56 PM
pv2dickman's Avatar
Default safc hack-missin link question
I keep reading that you don't need the missing link with a safc hack. My question is why not. Doesn't the engine still throw a code even with the safc in it.
I am just wondering if someone could explain to me why you don't need the missing link with the afc hack
Old Jun 10, 2005 | 05:47 PM
specv5150's Avatar
Default Re: safc hack-missin link question (pv2dickman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pv2dickman &raquo;</TD></TR><TR><TD CLASS="quote">I keep reading that you don't need the missing link with a safc hack. My question is why not. Doesn't the engine still throw a code even with the safc in it.
I am just wondering if someone could explain to me why you don't need the missing link with the afc hack</TD></TR></TABLE>
No, you do not need both. I am not 100% sure HOW the AFC works, read the hack FAQ on here. I guess for lack of a better explanation, when you use the bigger injectors and the AFC, you "trick" the ECU into not seeing the boost. The bigger the injectors, the more boost UNTIL you hit the MAP sensor limit of like 10-11 psi. Again read the FAQ to learn how it works. Trick is th eonly way I can explain it without reading the FAQ
here is the link.....there is also afc hack over at turbod16.com
https://honda-tech.com/zerothread?id=137901
Modified by specv5150 at 9:58 PM 6/10/2005
Old Jun 10, 2005 | 07:26 PM
Kendall's Avatar
An AFC alters the MAP signal to the ECU, and running the hack alters it to such a low point that the ECU will not be reading any boost. The only problem is that it really ***** up the ignition maps.
Old Jun 10, 2005 | 08:41 PM
pv2dickman's Avatar
Default Re: safc hack-missin link question (specv5150)
ahh.. just reading through that i figured it out..
thankyou
SOHCex20
Aug 2, 2005 11:30 AM
TurBoB20b
Mar 26, 2005 05:52 AM
BoOsTiN Dc2
Jan 12, 2004 03:24 PM
2muchPSI
Nov 18, 2003 01:03 PM
spoonfedls
Sep 9, 2003 08:30 AM
