safc and missing link quick question !!!!
Old Sep 8, 2003 | 03:23 PM
spoonfedls's Avatar
Default safc and missing link quick question !!!!
when running my Apexi SAFC, do i want the afc to read boost or not? im running an LS with custom turbo setup. to my understanding, honda MAP sensors are good up to 11psi. But a good friend of mine that i know is very knowledgeable with cars told me that once the computer reads boost it will throw the MAP sensor code and will run shitty and that i should run a missing link so that the ecu wont read boost. CAN SOMEONE PLEASE FURTHER EXPAND ME ON THIS!!!! ANY INPUT WOULD BE APPRECIATED. THANKS
Old Sep 8, 2003 | 03:37 PM
spoonfedls's Avatar
ttt
Old Sep 8, 2003 | 04:21 PM
boosted_dc2's Avatar
Default Re: (spoonfedls)
if your running a missing link then the afc should not register any boost.. it should go up to +/- 0. It should not go to + anything. If it does your missing link is junk...hope this helps.
Old Sep 8, 2003 | 04:26 PM
spoonfedls's Avatar
thanks, so what you are saying is that i need the afc to read 0 boost rto run correctly?
Old Sep 8, 2003 | 04:45 PM
no not all the time, when your boosting thats what you want it to say. When your idling if it says that then you got problems bro....
Old Sep 8, 2003 | 06:24 PM
spoonfedls's Avatar
thanks alot. just pmed him but anymore info would be great
Old Sep 9, 2003 | 06:41 AM
this guy is wrong.....the only way you wont get a cel with an afc is if your trimming the fuel like -36%. You didnt say you were running 440's or anything so im assuming your running the stock injectors. If you are running 440's or similar then you dont need a missing link. If you run any boost to the stock map sensor and the afc is not trimmed then you will throw a code.
Old Sep 9, 2003 | 07:56 AM
greekspeed's Avatar
Default Re: (hooked_up_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooked_up_gsr &raquo;</TD></TR><TR><TD CLASS="quote"> If you are running 440's or similar then you dont need a missing link. If you run any boost to the stock map sensor and the afc is not trimmed then you will throw a code. </TD></TR></TABLE>
well wont the map sensor read boost regardless if the afc is trimmed or not?
Old Sep 9, 2003 | 08:15 AM
Default Re: (greekspeed)
it will read boost but the computer wont see it because the afc cuts the signal voltage by -36% or whatever the setting is.... its just enough to keep it from throwing a code. jsut do a search on afc hack and youll find tons of info...
Old Sep 9, 2003 | 08:21 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Quick question when you say afc are you reffering to a v-afc or an s-afc?
Old Sep 9, 2003 | 08:30 AM
Default Re: (v-attack)
it doesnt make a difference they both do the same thing, (ex. vtec control obviously)
D16-t_coupe
Dec 2, 2007 04:19 PM
abmerop18
Jun 2, 2006 05:35 PM
zexifiedlude
Nov 27, 2005 07:47 PM
01ITR#700
Mar 4, 2003 12:17 PM
Turbohatch
Jul 2, 2001 10:35 PM
