Running hot
Old Aug 25, 2004 | 10:07 PM
slowassR's Avatar
Default Running hot
My buddys car is starting to run hot when he stops for stop lights. What can this be.. leakin in radiator... thermostat? any help would be awesome!
Luke
Old Aug 25, 2004 | 10:13 PM
Sack Master's Avatar
Default Re: Running hot (slowassR)
Flush the system, change the water pump, get a new thermostat, you should be the one telling us if its leaking not us telling you.
Old Aug 27, 2004 | 09:23 AM
slowassR's Avatar
Default Re: Running hot (mrspeaker)
alright.. thanks for the help .. I'll tell him to start with the thermost.
Old Aug 27, 2004 | 09:34 AM
Crazydave's Avatar
1.) check coolant level
2.) check fan operation (it should turn on and off)
3.) look for leaks
4.) check temps of inlet & outlet hoses
Old Aug 27, 2004 | 09:37 AM
Crazydave's Avatar
Default Re: Running hot (Crazydave)
I'd check the fan operation first.
if the fans don't turn on,
try turning on the a/c and see if the fans turn on.
if they do you might have a bad temp switch
if they don't you may have burned out fuse or a fan motor or loose wire.
how old is the radiator
hotcivicsi
11
Apr 9, 2009 06:19 PM
white98gs-r
Apr 5, 2009 06:51 AM
Donhonda84
Apr 4, 2007 08:36 PM
Cuda
Mar 21, 2007 11:25 PM
crxhftosi
Feb 22, 2005 07:53 AM
