Rod & Main Bearing question
Old Dec 9, 2003 | 04:09 PM
shannon's Avatar
Default Rod & Main Bearing question
How do you know if your rod bearings or main bearings need to be replaced or that they are going bad without dissasembling your motor ?
Old Dec 9, 2003 | 04:13 PM
Kendall's Avatar
Are they making any noise?
Old Dec 9, 2003 | 05:15 PM
shannon's Avatar
Default Re: (dc231)
The motor makes a kinda like ticking noise and a low banging noise at cold startups for like 2 sec.
Old Dec 9, 2003 | 05:16 PM
ShowSi2's Avatar
Default Re: (dc231)
check for noise and if your wondering they are that expensive to replace so be safe...
Old Dec 9, 2003 | 05:49 PM
seerx's Avatar
bad main bearings =low oil pressure
Old Dec 9, 2003 | 05:58 PM
boostn420's Avatar
Default Re: (seerx)
You can tell if its a rod bearing if the noise goes away when you pull the plug wire off for that cylinder while its running.
Old Dec 9, 2003 | 06:17 PM
shannon's Avatar
Default Re: (boostn420)
ttt
Old Dec 10, 2003 | 05:41 AM
shannon's Avatar
Default Re: (shannon)
ttt
Old Dec 10, 2003 | 07:44 AM
vtecb20coupe's Avatar
B A N N E D
where is the ticking coming from? or are you just listening for it away from the motor?
Old Dec 10, 2003 | 06:25 PM
fox297's Avatar
Default Re: (vtecb20coupe)
I think if your bearings are going bad, then your engine would produce a lot of vibration.
Old Dec 14, 2003 | 07:26 AM
shannon's Avatar
Default Re: (fox297)
I'ts can't describe where it comes from I just hear it coming from the motor at cold start ups
Old Dec 14, 2003 | 07:36 AM
Kendall's Avatar
I'm thinking it could very well be any number of problems caused by lack of oil pressure. Without oil pressure on startup you can be any number of moving parts making noise due to lack of proper lubrication. I'd have everything checked. It may be time for a good ol' overhaul.
Old Dec 14, 2003 | 07:43 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shannon &raquo;</TD></TR><TR><TD CLASS="quote">I'ts can't describe where it comes from I just hear it coming from the motor at cold start ups</TD></TR></TABLE>
replace your oil filter
there is a valve in the filter that prevents all the oil draining out of the oiling system when you turn the car off
it sounds like the pump is having to rebuild all the pressure every time you start the car, thats bad.
this would be the easiest and cheapest thing to replace before you start trying to diagnose spun bearings.
Old Dec 14, 2003 | 07:50 AM
Kendall's Avatar
I agree, very realistic possibility.
Old Dec 17, 2003 | 10:12 AM
shannon's Avatar
Default Re: (jerseykid609)
I did replaced the oil filter but the sound stayed the same
Old Dec 17, 2003 | 10:21 AM
fulldragcrx's Avatar
even at idle in my B series crx it taps. i dont think i have even heard one b Series motor that didnt tap even a little. but as far as a noise on start up, try to see if time or temp makes it better or worse. Like, run your car till norm operating temp in achieved, then shut it down, then an hour later restart it and see if the noise happends, increas your time by the hour interval. or the temp method, try to park it in a garage or some sort of enclosure over night ( during the winter of corse) and start it in the morning see what you get and let us know. also what weight oil are you using? or do you park on a hill?
Old Dec 17, 2003 | 01:09 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shannon &raquo;</TD></TR><TR><TD CLASS="quote">I did replaced the oil filter but the sound stayed the same</TD></TR></TABLE>
next is an oil pressure gauge.
20$ at any parts store for a cheap one, it will tell you how fast or slow you are building pressure.
Old Dec 18, 2003 | 04:09 AM
shannon's Avatar
Default Re: (Kamin)
Hi,after the engine cools for like an hour it makes the same noise at start up but a little bit more quiet not so loud
Old Dec 20, 2003 | 05:44 AM
hondamanwill's Avatar
Default Re: Rod & Main Bearing question (shannon)
sounds like a honda with some miles on it.(piston slap) as long as when it's warm the noise isn't there.
Old Dec 20, 2003 | 06:02 PM
Jaker's Avatar
Are you using OEM cast pistons or aftermarket forged ones?
Old Dec 21, 2003 | 07:30 AM
phatrick2332's Avatar
how about in his head? maybe between rocker and valve before the oil is there..just a possibility.
Since he said its only for a few seconds that its making the noise.
Old Dec 21, 2003 | 07:43 AM
blah13's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">how about in his head? maybe between rocker and valve before the oil is there..just a possibility.
Since he said its only for a few seconds that its making the noise.</TD></TR></TABLE>
Agreed, just sounds like lack of oil at startup + miles = noise.
corpsebesideme
Transmission & Drivetrain
Jul 19, 2017 07:38 PM
peakboosth22
Apr 1, 2007 01:25 PM
teddy_dc2
May 1, 2006 03:03 PM
ahunt01
Jun 21, 2003 05:11 PM
