rod knock??? searched
I just bought this car. I dont know if its a rod know or just need a really bad valve adjustment. It is really loud when you turn it on. when I drove it . it ran fine was doing 65 like nothing. It wasn't making a noise at this speed. But at a stop it will dye out. will be doing a compression test tomorrow.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">rod knock is also not continuous - it tends to happen under acceleration or load
valve chatter is all the time</TD></TR></TABLE>
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainy City »</TD></TR><TR><TD CLASS="quote">Take a hammer and hit your block with it. Thats what it sounds like.</TD></TR></TABLE> thanks will try that if its pston splap or rock knock it doesnt matter I just want to know if i should buy a new motor or fix the valve chatter
thanks
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">smart...
thats not really a very good explanation though, because piston slap will sound the same as that too</TD></TR></TABLE>
Well he shouldn't be getting piston slap when he's at operating temp unless his motor is on its way out.
Re: rod knock??? searched (92b16si)
my waterpump on my Ls sounded just like that, take a flat head screwdriver and put it to where you think the knock is, and listen to through the handle...
Re: rod knock??? searched (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 »</TD></TR><TR><TD CLASS="quote">Sounds like the valves, mine was doing the same thing and dying down when you stop.</TD></TR></TABLE> thats excatly what it does. how can you tell do I pull the head??? or what???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16si »</TD></TR><TR><TD CLASS="quote"> thats excatly what it does. how can you tell do I pull the head??? or what???</TD></TR></TABLE>
Pull the valve cover off and bring the #1 piston to TDC and check the clearance on the rockers.
Pull the valve cover off and bring the #1 piston to TDC and check the clearance on the rockers.</TD></TR></TABLE>
thanks will do this tomorrow
Modified by 92b16si at 10:38 PM 4/30/2007
Re: rod knock??? searched (Crispy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy »</TD></TR><TR><TD CLASS="quote">is the noise comming from the top or the bottom? I'd check that first</TD></TR></TABLE>
I cant tell
I cant tell
