Rod Bearings Please Help
Old Sep 25, 2002 | 02:54 PM
greenGSR12's Avatar
New User
Default Rod Bearings Please Help
I am rebuilding my 96 GSR engine and all I need are the rod bearings and main bearings. The crank was spun 10 10 by the machine shop. Acura says I need a color code for the bearings, I just dont know what color I need. Any help is appreciated. Thanks in advance.
Old Sep 25, 2002 | 03:17 PM
IN VTEC's Avatar
Default Re: Rod Bearings Please Help (greenGSR12)
I don't know what 10 10 means, but you can plastigage (green plastigage from Autozone) with a pair of green or yellow OEM bearings (which are middle of the scale in thickness) and then decide whether you need to go up or down in color.
You can also ask the machine shop what they turned the journals down to when they say 10 10.
Old Sep 25, 2002 | 08:05 PM
vhd's Avatar
vhd
you mean the crank journals(crankpin) and main journals was ground .010" under. i don't believe honda makes any oversize bearings. i know they make bearings in different thickness for std. size journals, but not undersized. your gonna have to go with an after-market company like acl, clevite, etc.....
Old Sep 25, 2002 | 08:35 PM
kinesistech's Avatar
I dont usually say use aftermarket, but there are some guys here who use them with great results. And if the crank was reground to different measurements they probably would be better. They use ACL bearings. Try a search for them, Im sure you'll find something from Mike I think. He has them for sale and swears by them.
Old Sep 25, 2002 | 10:02 PM
IN VTEC's Avatar
Default Re: Rod Bearings Please Help (kinesistech)
Talk to Rocket or earl about ACL bearings.
Old Sep 26, 2002 | 12:39 AM
Quik Chris's Avatar
Default Re: Rod Bearings Please Help (IN VTEC)
Yeah, I bought some ACL berings from earl through another friend on H-T. Unlike stock Honda berings which use a color code stamped on the bottom of the rods, then the code refers to another in the helms. The ACL's are manufactured to fit w/in the max and min tolerances of nearly all Honda motors, unless your motor was made on a Friday at 3:30pm when the tolerances are all off.
Don't forget about thrust washers too, don't want your crank moving around. The GS-R acutally uses the berings made for D16's when it comes to ACL. All mine plasticgauged perfectly. Oh, and ACL berings cost A LOT less than OEM Honda berings. $110 for rod, main, and thrust washers. Honda berings are too expensive to buy to see if they'd fit.
Old Sep 26, 2002 | 07:46 AM
earl's Avatar
Default Re: Rod Bearings Please Help (Midori Shinkansen)
I sell .25 mm oversized ACL bearings which will work with your 10 10 crank. This means rods and mains were ground .010 undersized and you need the .010 (.25mm) oversized bearing. E-mail me for details.
BTW, I just did a rebuild on a JG built motor. I found .25 mm oversized ACL's in it. Shocked me and especially my customer. They did not tell him.
Old Oct 28, 2002 | 04:30 AM
SpoonSportsJunkie's Avatar
Default Re: Rod Bearings Please Help (earl)
Acl bearings? how long has this company been making them? are there any professional race car teams that use them? Any road race or endurance race cars?
Old Oct 28, 2002 | 06:42 AM
earl's Avatar
Default Re: Rod Bearings Please Help (SpoonFanatic)
ACL is probably one of the largest bearing producers in the world. They build oem bearings for cars produced in many countries. Their quality is second to none. We are lucky to have this alternative to the stoch Honda bearings.
Old Oct 28, 2002 | 03:56 PM
How much does your company sell a package deal of these parts(rod, main bearings, thrust washers) for??
Old Oct 28, 2002 | 06:43 PM
earl's Avatar
$110 shipped for rods, mains and thrust. e-mail me if interested in purch
Old Nov 1, 2002 | 02:42 PM
Please post if any of you guys out there have used Fedral mogul bearings in your swaps? (Rod, main, and thrust ) What has been your experience with them? how many miles have you all gotten out of them? etc.. or
Old Nov 6, 2002 | 04:18 PM
Quik Chris's Avatar
ACL: As quality and inexpensive as you can get.
ACL gets:
I_eat_Rice
Jul 6, 2008 12:58 AM
crexer
Apr 12, 2007 01:05 PM
jtracing919
Feb 12, 2006 04:25 PM
Teg15
Sep 1, 2002 01:12 PM
CivicNewbie
Jan 24, 2002 10:42 AM
