rod bearing clearances
Old Apr 8, 2008 | 03:02 AM
hondatuning1989's Avatar
Default rod bearing clearances
searched and couldnt find out how to plastiguate the rod bearings...any advice...i dont see how you can do them like the main bearings where the caps come off SO hard
Old Apr 8, 2008 | 12:38 PM
Default Re: rod bearing clearances (hondatuning1989)
possibly plastiguage on the bearing thats closer to the piston than push it off that way???
Old Apr 8, 2008 | 04:39 PM
blkb18's Avatar
Get a pair of large channel locks, you can grab the small end of the rod (carefully of coarse) and wiggle it off. I assume the rods were resized?
Old Apr 8, 2008 | 06:10 PM
ekb16's Avatar
http://www.c-speedracing.com/h...s.php
Old Apr 15, 2008 | 02:25 PM
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...s.php</TD></TR></TABLE>
already looked there doesent help a bit...my prob is when i tap down on the rod to take it off the cap it squishes the plastiguage.
Old Apr 15, 2008 | 09:10 PM
00b18b's Avatar
apply assembly lube on the rod's dowel pins that way they slip on and off easier....i had this same problem
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
unknown0001
Jul 3, 2005 07:48 AM
Mad Cow Disease
Oct 2, 2003 01:55 PM
crx1856
Sep 18, 2003 08:29 PM
