connecting rod question
Old May 25, 2019 | 01:49 PM
5genhatch's Avatar
Default connecting rod question
picked up a b16 torn apart by original owner. no 2 cyl threw a rod bearing. I was able to put each rod cap to matched rod with help of a bright light and a magnifying glass. my question is does a bad rod bearing require the connecting rod to be replaced? I can't really find any online and would rather not spend 350 on a set of h beam rods. I sourced a new crank which is at the machine shop getting polished out right now.
Old May 25, 2019 | 06:54 PM
Honderachinaldo's Avatar
Default Re: connecting rod question
It depends on extent of damage. Visually examine big end bore of rod with bearing shells removed then compare bore and appearance with a micrometer with the other 3. rods bearings are a softer material and will generally tear the crank up before affecting rods. If you spun the bearing then the rod needs machine work or replacement.
Old May 25, 2019 | 06:56 PM
Lạc Việt audio's Avatar
How can i get it?
Old May 25, 2019 | 07:00 PM
I'd really like to see an aftermarket rod built for n/a that's lighter than factory yet adequately durable.
Old May 25, 2019 | 08:02 PM
motoxxxman's Avatar
just give the rods to the machine shop. they can mic them and see of they need re-sizing, which is fairly inexpensive. As long as there's no easily visible damage to the big end bore, they can usually be re-used no problem with proper sizing.
Old May 25, 2019 | 08:12 PM
Hey you can also inspect the big end bore for visual damage. D-f?
Old May 25, 2019 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Crower Max-Lite.
Old May 26, 2019 | 07:35 AM
Originally Posted by JRCivic1
Crower Max-Lite.
That's right. I never read specs on those, was just assuming they went for oe weight. Molnars were +35gr on f23, which isn't bad.
Um... yeah, If you didn't spin the bearing rod's prob fine(tboned the eff out his thread oops)
Old May 27, 2019 | 07:28 AM
5genhatch's Avatar
Thanks for the replies guys. So my thought are.. the engine didn't actually "spin" a bearing. There would be grooves from the lock tabs if I'm not mistaken.. and i can still see the cross hatched pattern on the rod surface itself. So i may be good to reuse these rods? That'll be my plan for now
Old May 27, 2019 | 08:48 AM
That cross hatch is exactly what u want to see. You could have it miked but I myself would use my powers of assumption and maybe plastigauge after reassembly in motor. Should be fine.
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
95hondasedan
Nov 17, 2014 07:45 AM
pjr710
Aug 18, 2008 11:18 PM
vteczone
Aug 6, 2008 10:51 AM
SOHCD16y8
May 21, 2005 12:32 AM
