Good idea to use ARP headstuds with Cometic gasket?
Old 05-15-2005, 11:44 AM
s2kkk's Avatar
Default Good idea to use ARP headstuds with Cometic gasket?
I got a .074" 4 Layer MLS head gasket from Cometic. I'm using the headgasket on my boosted B16. Should I use the ARP head studs or can I keep my stocks?
Old 05-15-2005, 11:56 AM
john d
Guest
Posts: n/a
Default Re: Good idea to use ARP headstuds with Cometic gasket? (spoon.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg &raquo;</TD></TR><TR><TD CLASS="quote">I got a .074" 4 Layer MLS head gasket from Cometic. I'm using the headgasket on my boosted B16. Should I use the ARP head studs or can I keep my stocks?</TD></TR></TABLE>
since your head is already off might as well replace them with arp's... save you the trouble down the road
Old 05-15-2005, 12:09 PM
saleensolution's Avatar
Default Re: Good idea to use ARP headstuds with Cometic gasket? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
since your head is already off might as well replace them with arp's... save you the trouble down the road</TD></TR></TABLE>
i agree use some studs they are stronger as well. i dont have much experience with thick head gaskets, but if your bolts are too short you may wanna look at getting some gsr studs they are a little bit longer than B16's
Old 05-15-2005, 12:11 PM
Benjithx's Avatar
Default Re: Good idea to use ARP headstuds with Cometic gasket? (saleensolution)
ARP is cool
Cometic is **** (their customer service anyway)
Old 05-15-2005, 12:17 PM
Default Re: Good idea to use ARP headstuds with Cometic gasket? (Benjithx)
the gaskets are good i have a friend that is making 497whp and had no problems with it
Old 05-15-2005, 12:36 PM
s2kkk's Avatar
Cool. Thanks for the fast feedback.
Old 05-15-2005, 12:51 PM
s2kdre's Avatar
you shouldnt reuse stock headbolts anyways
Old 05-15-2005, 12:56 PM
93LSivic's Avatar
Default Re: Good idea to use ARP headstuds with Cometic gasket? (jdmhonda)
Definetly use the ARP's, as stated above head bolts should not be re-used. I actually prefer AEBS, but I dont know how much longer they will be available due to AEBS closing its doors
Cometic gaskets are awesome, we use them in every application we work on.
Old 05-15-2005, 02:37 PM
s2kkk's Avatar
Default Re: Good idea to use ARP headstuds with Cometic gasket? (93LSivic)
I plan on getting new headbolts also. Going to go with the OEM headbolts though.
Old 05-15-2005, 03:22 PM
sohcT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">ARP is cool
Cometic is **** (their customer service anyway)</TD></TR></TABLE>
Cometic makes awesome hg's and their customer service is A+.
May I ask who you talked with in customer service.
1fastlude1
08-16-2008 06:14 PM
GooseS2000
04-11-2008 03:31 PM
Tuner Eddy
02-18-2008 09:23 PM
teddy_dc2
03-27-2007 08:06 PM
drumminforev
11
01-04-2007 01:39 PM
Quick Reply: Good idea to use ARP headstuds with Cometic gasket?
