Retarding timing
Back it down a few degrees then see how far you can bring it up without detonating.. On 9 PSI you probably wanna go back a little more than 2 degrees... Latez
you need to do more than just retard your timing if you want to achieve full potential out of the engine/turbo. But for now, retarding your timing will deffinately help with detonation
10 degrees from stock??? So your timing is at like 6 degrees?? What else are you running for fuel and ECU??
[Modified by JDMspecEG6, 6:39 PM 11/13/2002]
Is your motor internally stock?? My friend ran his B16 in his EK and pulled a 12.7@106 on 7psi... He was just running a Drag kit with stock ECU and VAFC.. Your RevHard kit is a lot better.. hehe
