replacing knock sensor on a prelude
Old Jun 20, 2002 | 09:05 AM
schwett's Avatar
New User
Default replacing knock sensor on a prelude
has anyone managed to replace the knock sensor on a 5th gen lude without taking the intake manifold off?
i'm getting p0325, knock sensor circuit malfunction........ i suspect i broke it while lugging the block around (although it didn't *look* broken.)
Old Jun 20, 2002 | 09:20 AM
Mikey3000's Avatar
Default Re: replacing knock sensor on a prelude (schwett)
you should be able to do it from under the car if it's in the same place as the 93-96's.
Old Jun 20, 2002 | 11:15 AM
schwett's Avatar
New User
Default Re: replacing knock sensor on a prelude (Boss Hogg)
sweet. i hope so.
Old Jun 20, 2002 | 12:41 PM
2point6's Avatar
Yes, you can remove the KS from underneith the intake manifold. It does require a 23mm (I believe will have to check later) deep socket to remove.
Lude Luna
Sep 19, 2015 11:34 AM
der3k
Apr 19, 2014 11:21 AM
JDMislander
Mar 26, 2010 06:01 AM
vinuneuro
Jun 2, 2006 06:07 AM
lv6l
Jan 2, 2005 05:55 PM
