knock sensor question
Old Jan 2, 2005 | 06:53 AM
lv6l's Avatar
Default knock sensor question
i would be guessing the knock sensor is located under the intake manifold on a 94gsr and its a piece of block that is hold up onto the intake manifold, can a missing nut/screw/bolt cause the knock sensor to not work properly??
it work fine before, but i took apart my head a few weeks ago and i remember taking out a screw or bolt or somthing under neath the intake manifold and i might forgot to put it back and now my check engine light is on, i was wondering can that cause anything or is my knock sensor broken and need changing?? thanks
Old Jan 2, 2005 | 03:34 PM
gt30typer's Avatar
Default Re: knock sensor question (lv6l)
Are you taking about the intake manifold support? I normally remove those and I ahve never had a problem.
Do the ECU reset procedure and see if you get a code again.
make sure the connection is good. knock sensors are crazy sensitive, I have seen people have problems with them by just unpluging them
Old Jan 2, 2005 | 04:19 PM
lv6l's Avatar
oh yeah probably my knock sensor is just loose or somthing, because the check engine light would not go on until i either drive agressively or iono when ever it wants, but yeah it doesn't go on all the time. and how do you reset the ECU. i tired unpluging the battery and plugging it back in but i doubt that would reset anything, can you tell me how you reset the ECU. thanks.
Old Jan 2, 2005 | 05:13 PM
gt30typer's Avatar
Default Re: (lv6l)
Disconnect the battery negative terminal , pull the ECU and back up fuses in the fuse box under the hood. Wait three minutes then put everything back and start the car , let it run for three minutes with out touching the gas pedal and it should clear the code and reset your ECU. You could simply have a failing knock sensor or it really is seeing knock under those load conditions. An easy way to test it is, run the car at 3000RPM for I believe a minute or two , if the code comes on you have a problem if not it is an intermitent code
Old Jan 2, 2005 | 05:55 PM
lv6l's Avatar
oh thanks, i'll try that
Corksil
27
Jul 14, 2011 06:10 PM
92'si
Feb 8, 2010 06:27 PM
odyssey2001
Acura TL, RL & ZDX
Dec 31, 2005 08:24 AM
98civic94gsr
Jan 20, 2005 04:17 PM
schwett
Jun 20, 2002 12:41 PM
