Replaced p72 with a P28 ecu Problem.
Old Dec 28, 2005 | 11:22 AM
Guru Designs's Avatar
* B A N N E D *
Default Replaced p72 with a P28 ecu Problem.
I recently purcheased a chipped p28 ecu for my gsr/itr setup. when i installed the ecu i removed the negative battery cable and removed the backup fuse then installed the ecu. i conencted the fuse then the neg cable then tried to start the car. it didnt start. i cranked it again and held the gas. it started but the main relay started clicking like MAD. and it would misfire and shut off. i removed the p28 and tried my p72 and it started fine. What could cause this problem a bad ecu? or maybe the chip in the ecu? thanks in advance
Old Dec 29, 2005 | 01:11 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Replaced p72 with a P28 ecu Problem. (tobe2be)
Could definatly be a bad chip. I have burned .bin files that have made the car run like crap. Contact Kenji for a good program. His site is in my sig, and he is on Honda-tech.
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
blackcivic11
17
Jul 24, 2009 01:32 PM
kentuckyhatch
Jun 30, 2009 10:05 AM
Guru Designs
Dec 28, 2005 09:33 PM
Turbo R
Dec 29, 2003 12:28 AM
