arp head studs stuck!!!!
Old Feb 10, 2010 | 05:57 PM
killacam661's Avatar
Default arp head studs stuck!!!!
i just pulled the head off my b20v and i cant bust the arp head studs loose. i have tried 4 different allen keys and they all strip!good thing they are craftsman . but what do i do? how do i get em loose so i can re torque down the head?
Old Feb 10, 2010 | 06:16 PM
10sec4door's Avatar
Default Re: arp head studs stuck!!!!
I had the same prob. with mines and they were golden eagle. A tard put locktite on mines thats why i thought mines were stuck. You can use a socket with an allen tip end. I would just put the head on and re torque them.
Old Feb 10, 2010 | 06:22 PM
ashb82's Avatar
Get you to nuts that fit the studs threads. Screw them both on, loosing the bottom nut tighten the top nut. Wedge the nuts together tight then loosing the stud with the bottom nut
http://www.dsmtuners.com/forums/arti...old-studs.html
ninesecrx's Avatar
Put a stud puller socket on them. But if you just wanted to tq the head back down why not just leave them and throw the head back on?
Old Feb 10, 2010 | 06:28 PM
vwbased's Avatar
Have a nice day
Old Feb 10, 2010 | 06:29 PM
boostedEF91's Avatar
x2 easiest way to do it. just use to arp nuts. screw them both on tightin them together. then turn the bottom nut and the stud will twist right out. the allen holes on top are junk. can never get them back out with doing it that way.
Old Feb 10, 2010 | 06:30 PM
ls_on_boost's Avatar
get a blow torch and heat them up then use two nuts to pry them or pressure pliers loose works for me when i strip a stud that i can't get loose
Old Feb 10, 2010 | 06:31 PM
because you arent supposed to tighten them down all the way(like 100ft pounds like mine are), they are ment to be loose in the block. im trying to put my head on one time and not mutiple times, i got the motor how it was and i bet the dumbass just tightened up every head stud til his butthole squeeked lol.
Old Feb 10, 2010 | 06:32 PM
ok i will be doing it this way. thanks everyone for the quick responses!
Old Feb 10, 2010 | 07:07 PM
jdm inc's Avatar
x3
Old Feb 10, 2010 | 07:16 PM
ashb82's Avatar
dont do this on a arp you will not be able to reuse it. I heat treat steel at work you will destroy the studs hardness and tensile strength
Old Feb 10, 2010 | 10:33 PM
HiProfile's Avatar
As long as it doesn't get past 500C for a few minutes, it won't affect it's physical properties. However I think he infered to not reuse the arp's after this, as he does it to pre-ruined studs.
THe double-nut method would work, but make sure you have the flange/wide surfaces of each nut facing each other. If not, the surfaces will deform and ruin the nut. Also try to do it nearest the top of the stud just in case you wrench it too much. Stretching that last 3/8" won't affect anything except aesthetics. If they used locktite, you will have to remove it ALL before retorquing. That means using a thread chaser and thread file (or thread cleaner).
Old Feb 11, 2010 | 05:15 AM
boostedcivicsir's Avatar
Mr. Badwrench
heating the stud will expand it. if you are to do it this way, heat it, then let it cool so you arent trying to turn a stud that is even larger than it was when it started. you generally want to heat the hole the fastener is in.
i think ninsecrx has the idea, i was thinking the same thing. stud extractors FTW> of double nutting.
Old Feb 11, 2010 | 07:10 AM
twkdCD595's Avatar
I agree with most of whats said above.
Sounds like someone loctited the studs into the block on assembly and they are firmly still in place. Might as well leave them alone as someone else said if the deck is ok and put the head back on.
If you bent on getting them out, double nut them with some high grade nuts so you dont tear up the arp hardware.
Heating metal causes it to expand, which would be making the problem worse not better if you try to remove it hot. No reason to use pliers, its not stripped... pliers will ruin the threads. Double nutting it would be the better option.
Old Feb 11, 2010 | 08:28 AM
i did the double nut method. they came out very easaliy. and i used the arp nuts. it didnt even take that much force to break them loose.
civicb18Tkid
May 3, 2007 07:30 AM
tuan...
Sep 22, 2004 09:33 AM
tuan...
Sep 22, 2004 04:57 AM
Convoy
Mar 5, 2003 01:02 PM
