tranny issues first n second never want to go in..
What's up HT. I've been having this problem wit my Tranny for a bit now. After breaking diffs, Couter shaft, and 2nd gr at different times now that its all together for the fourth time I'm still having trouble getting it in to1st n 2nd especially when i come to stops n red lights. Ive changed 1st n 2nd gr syncro twice. Completelycleaned it out. Replaced the counter shaft bearing that sits in the bell housing do to the counter shaft wearing it out for some reason and last thing i just did was juts bout a new linkage from has port n still doing the same Is there anything else i should check b4 i go get a new tranny?
Re: tranny issues first n second never want to go in..
after all that and no changes id suspect a bent fork?
mine wouldnt go in third before the dogbox and same thing after i installed it, put a solid joing in my linkage and fixed it, assumed it was bent or highly worn out.
I even changed the clutch master n slave. I thought it could be the clutch ( exedy twin disc) but the tranns still doesnt want to go into 1st or 2nd even when the car is off..
this is of no help.. but i do hope these seasoned guys can steer you into the right direction as far as ur trans woes (wobley/bent and straightend linkage possibly?)
as for myself.. i wonder.. are you the bad guy in RushHour 2 ? the one who owns the red dragon boat? LOL!
It's either the SCHA or the forks. It's that simple, especially if you're using an OEM based shifter assembly.
I had that issue and it was my cheezy carbon synchros. The synchro sleeve was digging into the thick notches on the outside of the synchro. I put in a stock synchro and never had the issue again. I was having to start the car in gear etc.
snatch
06-09-2004 07:52 PM
VTEC-DA
04-03-2003 06:15 PM
B18C5-EH2
11-13-2001 01:59 PM
