optima battery install
Old Jul 31, 2002 | 06:25 PM
rasta420's Avatar
Default optima battery install
sup guys,
im about to install my new yellow top optima battery in the trunk. i had a couple of questions for those who had already done a battery relocation to the trunk, or just battery experts.
1) i have a amplifier ground wire that i put near the spare tire area. can i put the battery ground in the same place, or do i need a new ground area for the battery ground?
2) is it ok to just solder the positive cable to my monster cable up in the engine bay and then tape it up?
3) what should i do with the ground cable in the engine bay? tape it up and zip tie it somewhere?
4) should i install a fuse for the positive cable going to the battery?
thanks
Old Jul 31, 2002 | 11:28 PM
Dee's Avatar
Dee
Default Re: optima battery install (rasta420)
Are you installing it as a 2nd battery or as the main battery? Contrary to common belief Optima batteries will fit in the front of the car. All you have to do is trim the extra plastic off the bottom of the battery (do NOT trim any of the cylinder plastic).
1) Ground the battery to any good contact point try to keep the cable short.
2) Use some type of distribution block because you will need a contact point for additional 12v connections.
3) just disconnect it and put it away for safe keeping.
4) use a stereo circuit breaker for the battery if you are relocating the main battery to the rear of the car. Use atleast a 100amp breaker.
Use atleast 2 gauge wire to connect the battery to the main fuse block. Using a (1) 2 gauge to (4) 8 gauge distribution block will make things easier on the eye and will give you two extra 8 gauge 12v access points.
Old Aug 7, 2002 | 02:43 PM
krazy's Avatar
Default Re: optima battery install (Dee)
Dee: u have more pics of the battery install? i wanna see how u did it, and if it is worth the hassle.
krazy
Old Aug 7, 2002 | 10:48 PM
Dee's Avatar
Dee
Default Re: optima battery install (krazy)
I'll try to snap some this weekend while I am working on my stereo!
longdongdan96
Audio / Security / Video
Jan 28, 2004 12:27 PM
rasta420
Jul 31, 2002 08:48 PM
ezark
Jun 26, 2002 10:38 AM
DAYUIZ
Dec 27, 2001 05:32 PM
91sifreak
Apr 18, 2001 07:36 AM
