rapid misfire problem. please help!
Old Aug 10, 2005 | 05:17 PM
-DC2-'s Avatar
Default rapid misfire problem. please help!
ok, here's the deal. my d16z6 has a rapid misfire problem under moderate load and below 3k rpms or so. significant loss of power while misfiring. it sounds kinda like a fully automatic machine gun going off. after ~3k rpms it pulls normally with full power.
new parts:
timing belt/h2o pump
cap/rotor
primary ground wires
spark plugs (gap at 1.1mm = OE spec)
i have tried a second MAP sensor, and both behave the same
everything is normal. timing is dead on and checked with a timing light. idle is stable, but when the radiator fan comes on, it struggles to stay running. ideas?
edit: CEL is off
Modified by DOHCDX at 11:37 PM 8/10/2005
Modified by DOHCDX at 11:38 PM 8/10/2005
Old Aug 10, 2005 | 06:20 PM
-DC2-'s Avatar
Default Re: rapid misfire problem. please help! (DOHCDX)
i need some ideas, guys.
Old Aug 10, 2005 | 07:16 PM
-DC2-'s Avatar
i swapped in a second coil tonight. no change.
Old Aug 10, 2005 | 10:22 PM
Sinner's Avatar
hows your alternator/ battery? Did the problems occur after you replaced those parts? My car has similar problems when the alternator/battery was going. One went causing the other to go bad i think.
Nick
Old Aug 10, 2005 | 10:31 PM
PURPLETERROR aka BIGMATT's Avatar
It sounds like you are off a few teeth on the timing
Old Aug 11, 2005 | 04:25 AM
-DC2-'s Avatar
timing is dead on, and confirmed with a light. that is not the problem.
i will be putting in new plug wires, and trying a second ignitor tonight.
after swapping the engine in it misfired a bit under 3krpms and idled really rough. well, the #1 spark plug wasn't gapped properly. once i gapped it to 1.1mm, the idle stabilized, and this "rapid misfire" started up.
Built2NV
May 8, 2011 08:19 AM
JdmSpecTeggy
22
Oct 15, 2009 10:04 AM
stocker2shocker91
Mar 22, 2008 03:52 PM
90lshatch
Mar 28, 2006 08:14 PM
Retard324
Oct 4, 2005 08:20 AM
