obd conversion
Old Aug 22, 2007 | 10:01 AM
soon2bdropped's Avatar
Default obd conversion
quick question say if i have an obd1 integra with obd 2 motor.. it wont work right.. because the harness plugs that goes to the ecu are different.,.
if i tried obd2 integra with obd1 motor why won't it work.. if i used an obd1 computer along with obd1 motor..
something is confusing me here..
Old Aug 22, 2007 | 10:11 AM
l2Y4N's Avatar
Default Re: obd conversion (soon2bdropped)
well obviously, obd1 engines need obd1 ecus, obd2 engines need obd2 ecus, unless you have a conversion harness.
Old Aug 22, 2007 | 11:33 AM
Default Re: obd conversion (l2Y4N)
why can't an obd2 car work with a obd1 motor with obd1 ecu?
and vise versa?
Old Aug 22, 2007 | 03:17 PM
l2Y4N's Avatar
an obd2 car will have a different wiring harness as well as extra sensors that wouldn't be used on an obd1 car. it could probably work, but my guess is youd have to cut and splice some wiring.
Old Aug 22, 2007 | 10:48 PM
Mfoehrkolb's Avatar
you can buy
OBD1 to OBD2 Step up
&&&&&&&&&&&&&&&&& ON EBAY!!!!!!! look it up bro
OBD2 to OBD1 step down
Old Aug 22, 2007 | 11:06 PM
BlakeJ53's Avatar
Default Re: obd conversion (Mfoehrkolb)
Any gsr OBD1 or OBD2 harness should plug in to a gsr or ( EG civic ). Yes you can put a OBD2 gsr motor in to an OBD1 car. I know this because I have a OBD2 gsr harness in my 93 civic that is being run off a OBD1 ecu. You also can use a OBD1 motor in a OBD2 car, you will just have to change the dizzy, injectors, alternator, to OBD2, and you will have to add some censors like crank shaft position censor ect ect.
Old Aug 22, 2007 | 11:08 PM
Mfoehrkolb's Avatar
another thing to consider:
OBD1 = less engine lights going off
OBD2 = more engine lights going off
Old Aug 23, 2007 | 11:58 AM
GSR-TRBO-DA's Avatar
it's scary that you have almost 800 posts and you still don't know the basics..
Old Aug 23, 2007 | 12:17 PM
BlakeJ53's Avatar
Default Re: obd conversion (GSR-TRBO-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA &raquo;</TD></TR><TR><TD CLASS="quote">it's scary that you have almost 800 posts and you still don't know the basics.. </TD></TR></TABLE> I agree
Old Aug 23, 2007 | 02:05 PM
Mfoehrkolb's Avatar
Default Re: obd conversion (BlakeJ53)
ditto. just by honda teching it up, you learn additional things about your car if you just read and look around for post. spendsometimelovingyourhonda
Old Aug 23, 2007 | 05:20 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">you can buy
OBD2 to OBD1 step down </TD></TR></TABLE>
We had a customer bring in an ebay kit, it was wired wrong and cause the car to throw codes, to ebay wiring harness.
Old Aug 23, 2007 | 06:35 PM
Mfoehrkolb's Avatar
was is installed correctly or jjust a person tryin to plug and play wrong way?
Old Aug 23, 2007 | 06:40 PM
Default Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">was is installed correctly or jjust a person tryin to plug and play wrong way?</TD></TR></TABLE>
We installed it, so it was installed correctly. And I knew it was the wiring harness because I swapped it out with a rywire ( cause we stock them ) and it fixed the problem.
Old Aug 24, 2007 | 10:21 AM
Default Re: (RCautoworks)
if thats the case why wouldn't a obd2 civic like a 97 with a b16 swap we couldn't use the harness.. motor was 99-00 si..
even the computer which is the si computer didn't plug in with the b16 wire harness,.. **** is confusing me..
Old Aug 30, 2007 | 10:13 AM
Default Re: (soon2bdropped)
OKay theres an engine harness and ecu harness.. some cars has both together with the ecu harness..
i can understand if the ecu harness is different but what if its not.. i'm so confused..
Old Aug 30, 2007 | 10:32 AM
you can use an obd2 motor in an obd1 chassis
you can use an obd1 motor in an obd2 chassis in both cases u use can use the same harness that came with the chassis. so you don't convert the harness you convert the ecu. but only for the obd2 chassis will you convert it to obd1 becaus if you have an obd1 chassis then you are already obd1 . u want obd1 for performance reasons. you need to be more specific. what is it that you are doing? are you pulling a swap? if so what chassis, what motor, what year motor, and what year chassis?
88-91=obd0
92-95=obd1
96-98=obd2
99-2000=obd2a as far as honda/acura is concerned
mcloven
Jun 30, 2008 06:54 PM
topherchris
Sep 26, 2007 07:30 PM
NOman0608
Jul 26, 2007 10:28 AM
akoreanyoungsta
Jul 8, 2006 06:22 PM
D16Z6racing
12
Jul 26, 2002 02:15 PM
