Question about using Plastigage
When plastigaging the main bearings, is this the correct procedure :
1. Install ALL the bottom half bearings in the main journals (in the block)
2. Install the Crankshaft
3. Place a piece of green plastigage strip on 1st crank journal
4. Install bearing half in corresponding main cap
5. Lube main bolts with 30W Oil and torque main cap to specs
6. Remove main cap and measure crushed plastigage to compare with manual.
Am I doing this correctly in the steps I came up with?
Exactly. Put it together as you're going to final assemble it with the proper torque sequence then there is no question of whether or not things were exactly the same when you clearanced it.
bearing, bearings, gsr, halves, honda, instructions, main, manual, plastigage, plastigauge, purpose, race, s2000, sold, strip
HT is not as bad as other forums make it sound
