main bearing oil clearance
building an ls turbo engine, stock crank micropolished, got some new acl race bearings, went to install today and the tolerance was out, standard is .0009 to .0017 and max is .002...im reading .003 on all journals, i did not notice any other sizes of bearings other then standard ones...what can I do? Also i have golden eagle studs and install says to torque to 10 pounds then put the mains on and torque the nuts to 56 pounds, and when i went to losen the nuts off to check my clearances the studs came loose from the block as well, it says not to over tighten the studs...is this normal?
