Question about using Plastigage
Old Apr 27, 2011 | 08:04 PM
gizmoto2000's Avatar
Default Question about using Plastigage
When plastigaging the main bearings, is this the correct procedure :
1. Install ALL the bottom half bearings in the main journals (in the block)
2. Install the Crankshaft
3. Place a piece of green plastigage strip on 1st crank journal
4. Install bearing half in corresponding main cap
5. Lube main bolts with 30W Oil and torque main cap to specs
6. Remove main cap and measure crushed plastigage to compare with manual.
Am I doing this correctly in the steps I came up with?
Old Apr 28, 2011 | 01:54 AM
blackedEk's Avatar
Default Re: Question about using Plastigage
sounds good to me
Old Apr 28, 2011 | 03:29 PM
When torquing the bolts, do I use just regular 5w30 or 10w30 or does it have to be just 30W straight? Can I use Lucas Oil Stabalizer?
Old Apr 28, 2011 | 03:32 PM
blackedEk's Avatar
5w30 or 10w30 should do it
Old Apr 29, 2011 | 04:47 AM
Blown90hatcH's Avatar
I personally install all the main caps and torque the entire sequence. Then reverse in correct order and measure all of them at once.
Old Apr 29, 2011 | 07:08 AM
mik101's Avatar
Exactly. Put it together as you're going to final assemble it with the proper torque sequence then there is no question of whether or not things were exactly the same when you clearanced it.
Old Apr 29, 2011 | 06:38 PM
Ok thanks guys HT is not as bad as other forums make it sound
Old May 2, 2011 | 12:28 PM
razorlude's Avatar
i think the purpose of the oil are just for the accuracy of the tightening torque...
Lil_Wyte
Mar 26, 2011 09:43 PM
Lil_Wyte
Mar 26, 2011 08:36 PM
GSR_hatch936
May 27, 2008 06:36 PM
(puma)
Oct 22, 2005 12:59 PM
na200whp
Nov 1, 2004 08:22 PM
