puttin obd-1 motor in obd 2 car
Old Apr 27, 2003 | 01:15 PM
EK Hybrid's Avatar
Default puttin obd-1 motor in obd 2 car
i just bought a complete obd-1 gsr that was wrecked and am transferring everything to my 96 EK. now i have searched old threads and found that i need the jumper harness to plug in the obd-1 computer, so i'm ordering that. also, i found that it would be easier to get a 96-98 vtec harness out of a 96-98 ex, and if i bought both of those things would i still need to change the alternator, injectors and distributor even though i am using a obd-1 computer? i was thinking i could just buy those to things and go, since ill have all the mounts, linkage, axles, etc...already. or am i missing the whole picture completely?
Old Apr 27, 2003 | 04:43 PM
EK Hybrid's Avatar
Default Re: puttin obd-1 motor in obd 2 car (EK Hybrid)
anyone?
Old Apr 28, 2003 | 04:48 AM
EK Hybrid's Avatar
bump
Old Apr 28, 2003 | 01:51 PM
EK Hybrid's Avatar
no one has any info? i did a search and i didnt answer my question for my particular application.
Old Apr 28, 2003 | 03:02 PM
HXMan's Avatar
The OBD1 alternator, and injectors won't plug into a OBD2 harness.
Everything else should work.
YOu have an adaptor to run the OBD1 ecu right?
Old Apr 28, 2003 | 06:30 PM
EK Hybrid's Avatar
Default Re: puttin obd-1 motor in obd 2 car (HXMan)
im ordering a harness from the guy on here thats doin a GB on them.
Old Apr 28, 2003 | 11:16 PM
MPower332TI's Avatar
Ok you are gonna have to rewire the distrubutor because the gsr has 2 plugs where as 96-98 civics have one.If you have the gsr harness then itll save you some trouble, if you do you need to use the alternator plug off of it and wire it into the 96-98 ex harness. You could also do that on the injectors by clipping some wire off and wiring them into the 96-98 civic harness. Youll also have to change the plug on the iat sensor and the iac valve. Pm me when youre doing the swap if you need any help.
ed6nate
Nov 9, 2018 11:28 AM
efrunner09
10
Sep 21, 2009 02:57 PM
cthan3o3
13
Jul 31, 2005 08:27 AM
mooseknuckle
Apr 5, 2004 06:05 PM
TURBOED-TEG
Sep 14, 2002 02:28 PM
