Project Integra - WTF - Exhaust glowing RED HOT !
Old Aug 16, 2003 | 10:50 AM
svtec's Avatar
L D E S
Default Project Integra - WTF - Exhaust glowing RED HOT !
Finally got '01 GSR started with the brake code.
The bastard stumbles around at low RPM's and the check engine light is on.
Looking under the car, the cat is glowing RED HOT under the heat shield.
What is going on? The cat is not supposed to get that hot is it?
Any sugestions . . .
Old Aug 16, 2003 | 10:52 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (svtec)
I have herd of the header getting that hot but the cat? Dude sounds like you have a clogged cat! Check it out and see.... does it smell bad when you start it?
Blaze
Old Aug 16, 2003 | 11:26 AM
toolowsol's Avatar
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (Blaze45)
try running open header and see if it runs any better, and what year is the car. obd1 or2
Old Aug 16, 2003 | 12:11 PM
VTEC-DA's Avatar
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">try running open header and see if it runs any better, and what year is the car. obd1 or2</TD></TR></TABLE>
Its a 2001 GSR. Its an OBD2 unless he has converted it, which he may have.
Old Aug 16, 2003 | 01:41 PM
svtec's Avatar
L D E S
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (VTEC-DA)
Yes, it's an OBD II 2001 GSR with only 9,700 miles! It's a theft recovery that I just put back together. All that was stolen were the seats, wheels and the ECU. I put an ECU from a 2000 GSR in it and started it with the brake code to drive it to the dealer for immobilizer reprogramming. It just runs like **** though. It has probably been sitting for close to a year, but WTF, it shouldn't be doing this. Maybe some mouse made a nest in my cat!
Old Aug 16, 2003 | 03:07 PM
fox297's Avatar
You have unburned fuel going through your exhaust, that's why your cat is melting. Some of the things I could think of right now are bent valves, foul plugs, foul injectors, bad o2 sensors.
Old Aug 16, 2003 | 04:23 PM
svtec's Avatar
L D E S
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (fox297)
Well, I know it's not the cat - disconnected it and still runs like ****!
With the cat off, you can really smell raw fuel. Could it have something to do with the fact that I have a 2000 GSR ECU in my 2001 car? I'm not aware of any difference between '00 and '01 - correct me if I'm wrong.
All I can think of is the ECU, do these computers go "bad"? Bought it used on "eBay Motors"
Old Aug 16, 2003 | 04:32 PM
vactor's Avatar
if you want helop on how to fix a problem, you need to tell us what you have done to the car. since you told us nothing, i will assume the car is bone stock with a stock replacement ecu?
Old Aug 16, 2003 | 07:41 PM
svtec's Avatar
L D E S
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (vactor)
yes. bone stock. period.
stock ecu replacement.
Old Aug 16, 2003 | 08:00 PM
fox297's Avatar
Your ecu might be running in "limp" mode. Try to see if you can rev the engine pass 3500rpm. Also, try to read the led from the ecu to see what code it's throwing.
Old Aug 16, 2003 | 08:51 PM
FastEK9's Avatar
did u by chance have the belt off or replaced?Check your timing belt make sure ish on the money.
Old Aug 17, 2003 | 01:33 AM
Sanj's Avatar
Sounds like ur Cat is blocked or raw fuel in being dumped into the catalytic convertor. Need ur help. Purchased a 2000 Integra GS has the dumb immobilzer system. Need to drive the car to the dealership. I can get brake code with the ownership no problem. How do i go about entering the code to make the car drivable? The car is a stolen and recovered. Ur help is much appreciated.
Sincerly
Sanj
Old Aug 17, 2003 | 07:42 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">You have unburned fuel going through your exhaust, that's why your cat is melting. Some of the things I could think of right now are bent valves, foul plugs, foul injectors, bad o2 sensors.</TD></TR></TABLE>
Old Aug 17, 2003 | 07:49 AM
haggar's Avatar
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (Sanj)
The stumbling is also probably caused by a really rich running condition. Or a fuel leak. Or a misfire. That would cause low rpm stumbling, and the cat to be overheating.
Check the Ignition system first, maybe you are running one 3 cylinders. One is dumping fuel and melting the cat.
Old Aug 17, 2003 | 08:29 AM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">Your ecu might be running in "limp" mode. Try to see if you can rev the engine pass 3500rpm. Also, try to read the led from the ecu to see what code it's throwing.</TD></TR></TABLE>
it'll rev past 3500, so apparently it is not running in limp mode. i'll check that code thing out.
Old Aug 17, 2003 | 08:31 AM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sanj &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like ur Cat is blocked or raw fuel in being dumped into the catalytic convertor. Need ur help. Purchased a 2000 Integra GS has the dumb immobilzer system. Need to drive the car to the dealership. I can get brake code with the ownership no problem. How do i go about entering the code to make the car drivable? The car is a stolen and recovered. Ur help is much appreciated.
Sincerly
Sanj</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=593470
try that, but dont read down to far.
Old Aug 17, 2003 | 09:49 AM
LudeyKrus's Avatar
if it was stolen, then it was prob. dogged out bad. make sure nothing internally is damaged, if nothing else is obviously wrong or busted.
Old Aug 17, 2003 | 10:29 AM
R6Boy69's Avatar
check the timing... this exact thing happened to me. The timing belt was off abit... so get the timing checked and I think you will find your problem.
Old Aug 17, 2003 | 07:38 PM
svtec's Avatar
L D E S
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (crXBoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">check the timing... this exact thing happened to me. The timing belt was off abit... so get the timing checked and I think you will find your problem.</TD></TR></TABLE>
i'll have to check that out.
Old Aug 18, 2003 | 01:40 AM
fu*kfaceC1EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">Finally got '01 GSR started with the brake code.
Any sugestions . . . </TD></TR></TABLE> try setting the car on fire.
Old Aug 18, 2003 | 09:56 AM
svtec's Avatar
L D E S
Default Re: Project Integra - WTF - Exhaust glowing RED HOT ! (fu*kface95hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fu*kface95hatch &raquo;</TD></TR><TR><TD CLASS="quote"> try setting the car on fire. </TD></TR></TABLE>
That's something that I've actually considered
Comptiateck
Nov 5, 2010 04:22 AM
DC2 Mang
May 29, 2006 10:06 AM
escape2me
Apr 20, 2006 09:17 AM
unlimited6986
Jul 14, 2005 05:22 AM
tyflip2
Jun 26, 2004 03:22 PM
