Problems in VTEC....
Old May 27, 2003 | 11:29 AM
Witty's Avatar
Default Problems in VTEC....
After VTEC engages it feels like I'm hitting my fuel cut off for a split second and does this several times before redline. It's like a sputtering? Don't really know how else to explain it. What do you guys think the problem could be? Fuel problem, detonation? Mods in sig
Old May 27, 2003 | 11:33 AM
10K2HVN's Avatar
Default Re: Problems in VTEC.... (Witty)
for some reason Fuel Injector Cleaner always works for me when that happens to my car....
Old May 27, 2003 | 11:39 AM
MikeSarr_GSR's Avatar
Default Re: Problems in VTEC.... (10K2HVN)
NO OIL MEANS NO VTEC
check your stick bro
Old May 27, 2003 | 11:50 AM
Witty's Avatar
Default Re: Problems in VTEC.... (MikeSarr_GSR)
Oil level is fine. First thing I checked.
Old May 27, 2003 | 12:01 PM
whens the last time you changed your fuel filter
Old May 27, 2003 | 12:05 PM
Witty's Avatar
It doesn't seem like it's coming out of VTEC, just not getting any fuel at all for a split second and then coming back strong. Like a hesitation. TPS maybe?
Old May 27, 2003 | 06:35 PM
Chiovnidca's Avatar
Is the check engine light on?
Old May 27, 2003 | 08:49 PM
g2 GS-Argh's Avatar
Check the resistances on your ignition coil. Mine has gone out 3 times now, and it feels like it's hitting fuel cutoff (usually under heavy load, such as VTEC).
Old May 28, 2003 | 06:10 AM
Witty's Avatar
Default Re: Problems in VTEC.... (g2 GS-Argh)
I'm not throwing any codes.
Team PHATBOYZ
Jun 6, 2008 05:09 PM
92ludef22
Apr 13, 2008 08:25 PM
preppy79
Jun 19, 2006 11:45 PM
1point7db2
Nov 9, 2004 10:39 AM
NeXtLeVeL_TyPe_R
Oct 4, 2001 02:26 PM
